Community Member
Extension Mobility
Hi, I had running extension mobility and at phone service I have create an extension moblity link and at the http link I only able to specify 1 ip address. When I want to down one of the server, I need to measure the link does not point to that server, if it is point to that server, I need to change it point to another server and re-sync it. If it is point to that that server and I does not change the http ip address, and down the server, it will cause all the extension mobility users not able to login. Can I know have any way I able to point to 1 ip address and during I down which server, I does not need to chage the extension mobility http link ip address?
Thank you.
John
1 REPLY
VIP Red
If you want to keep using an
If you want to keep using an IP address as your service URL, you can start using the IP address as a virtual IP address on a LOad balancer.
It would be easier though, to start using a hostname instead of an IP address for redundancy purposes.
Please remember to rate useful posts, by clicking on the stars below.
30
