Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Extension number range
Off the wall question, but does the Call Manager support extension numbers that begin with 0 or 9
DJE
1 ACCEPTED SOLUTION
Re: Extension number range
Sure, but you need to design your numbering plan wisely.
For example, if you have extensions that beging with 9 and you also add Route Patterns that beging with 9 (like 9.@) then you will have a delay (interdigit timeout) while placing PSTN calls.
//Jorge
//Jorge
CUCM takes any digits from 0 thru 9 for extensions, no limitations on that. Just as Jorge mentions choose wisely and take your time to define the dial plan
java
if this helps, please rate
java
www.cisco.com/go/pdi
104
