extension showing different behavior externally than internally
Morning friends,
I have a virtual VoIP solution.
  • Cisco Unified Call Manager - System version: 8.6.2.22900-9
  • Cisco Unity Connection - Version 8.6.2ES44.22900-44
I have one extension that behaves differently that all of the others. From my phone, when I dial the extension, 3515, the systems behaves properly. It rings the phone then after a few rings, then goes to voicemail.However, from the outside world, when someone dials the main corp phone number, (XXX) 674 - 1500,and enters the 4 digit extension, instead of ringing the end users phone ( like it should), it goes directly to voicemail.
I am sure it is a checkbox somewhere, but when I search around, I am unable to find
Any help is greatly appreciated
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi David,
Find the user in Unity Connection and check the "Transfer"
Rule settings;
Transfer Action
Transfer Calls To:
Cheers!
Rob
"A smile relieves a heart that grieves"
- Stones
1 REPLY
Hi David,
Rule settings;
Transfer Action
Transfer Calls To:
Cheers!
Rob
- Stones
73
