External Call not working on CUCM with SRST
External calling not working on CUCM while the same is working on SRST PRI gw. Debug router shows 'call allocation failed'.
any help?
Chris Deren
Can you post "debug isdn q931"?  Are you using off-net access code and stripping/not stripping it on CUCM?
Chris
acampbell
Hi --- Happy New Year,
Can you explain your set up Gateway type , CUCM versions etc
Can you post the router config
Alex
Regards, Alex. Please rate useful posts.
