external calls disconnect
CM 6.1
Phone 7937
I have installed a 7937 and internal calls in and out work fine
external incoming calls works fine
but external outgoing calls will ring but disconnect as soon as the user connects - have checked the config but cannot understand why this happens?
any ideas?
thanks in advance
1 ACCEPTED SOLUTION
Re: external calls disconnect
what codec are you using for the outgoing calls and are you using MGCP or H323?
sounds like a codec issue
java
if this helps, please rate
java
www.cisco.com/go/pdi
You'll need to give me the config of the PSTN gateway. Is this FXO, PRI or T1?
java
java
This was a routing issue and working fine now -thanks for the reply
155
