Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
External calls issue
I Have a CUCM with H.323 VG.
Recently we observed all of the 30 Channels of E1 not seem to be utilized . only 2-3 users are able to make Outgoing calls while rest of the users are getting Busy Tone , while trying to make an external call.
Can someone please tell the solution for this issue . currently out of 30 channels 25 channels are showing the Operation state a “dorm None “ while rest channels are “ Up “ in state .
RJ
Silver
Problem with ISDN LINES
Can you post your config?
You know that, even E1 by default is giving 30 channels, you can have much less available channels - based on what your provider is giving to you?
Can you post also "debug q931" messages?
HTH,
Dragan
HTH, Dragan
Please find the Sh Run and below to that debug isdn output
R1#sh isdn active
R1#sh isdn active
                                ISDN ACTIVE CALLS
Call    Calling      Called       Remote  Seconds Seconds Seconds Charges
Type    Number       Number       Name    Used    Left    Idle    Units/Currency
Out +8043306167  9886412218                  1162       0       0      0
Out    49365903 +6832001250                    95       0       0      0
Out    49365827  9632551516                    49       0       0      0
Out         171  9620173492                    22       0       0      0
Out         363  9902052420                    19       0       0      0
R1#
R1#
R1#
R1#sh isdn serv
R1#sh isdn service
PRI Channel Statistics:
ISDN Se0/0/0:15, Channel [1-31]
  Configured Isdn Interface (dsl) 0
   Channel State (0=Idle 1=Proposed 2=Busy 3=Reserved 4=Restart 5=Maint_Pend)
    Channel :  1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1
    State   :  2 2 2 2 0 2 0 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
   Service State (0=Inservice 1=Maint 2=Outofservice 8=MaintPend 9=OOSPend)
    State   :  0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
ISDN Se0/0/1:15, Channel [1-31]
  Configured Isdn Interface (dsl) 1
    State   :  2 2 2 0 0 0 0 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
R1#
R1#
R1#
R1#sh voice
R1#sh voice po
R1#sh voice port sum
R1#sh voice port summary
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0:15        01  isdn-voice  up    up   none     none     y
0/0/0:15        02  isdn-voice  up    up   none     none     y
0/0/0:15        03  isdn-voice  up    up   none     none     y
0/0/0:15        04  isdn-voice  up    up   none     none     y
0/0/0:15        05  isdn-voice  up    up   none     none     y
0/0/0:15        06  isdn-voice  up    dorm none     none     y
0/0/0:15        07  isdn-voice  up    dorm none     none     y
0/0/0:15        08  isdn-voice  up    dorm none     none     y
0/0/0:15        09  isdn-voice  up    dorm none     none     y
0/0/0:15        10  isdn-voice  up    dorm none     none     y
0/0/0:15        11  isdn-voice  up    dorm none     none     y
0/0/0:15        12  isdn-voice  up    dorm none     none     y
0/0/0:15        13  isdn-voice  up    dorm none     none     y
0/0/0:15        14  isdn-voice  up    dorm none     none     y
0/0/0:15        15  isdn-voice  up    dorm none     none     y
0/0/0:15        17  isdn-voice  up    dorm none     none     y
0/0/0:15        18  isdn-voice  up    dorm none     none     y
0/0/0:15        19  isdn-voice  up    dorm none     none     y
0/0/0:15        20  isdn-voice  up    dorm none     none     y
0/0/0:15        21  isdn-voice  up    up   none     none     y
0/0/0:15        22  isdn-voice  up    dorm none     none     y
0/0/0:15        23  isdn-voice  up    dorm none     none     y
0/0/0:15        24  isdn-voice  up    dorm none     none     y
0/0/0:15        25  isdn-voice  up    dorm none     none     y
0/0/0:15        26  isdn-voice  up    dorm none     none     y
0/0/0:15        27  isdn-voice  up    dorm none     none     y
0/0/0:15        28  isdn-voice  up    dorm none     none     y
0/0/0:15        29  isdn-voice  up    dorm none     none     y
0/0/0:15        30  isdn-voice  up    dorm none     none     y
0/0/0:15        31  isdn-voice  up    dorm none     none     y
0/0/1:15        01  isdn-voice  up    up   none     none     y
0/0/1:15        02  isdn-voice  up    up   none     none     y
0/0/1:15        03  isdn-voice  up    up   none     none     y
0/0/1:15        04  isdn-voice  up    dorm none     none     y
0/0/1:15        05  isdn-voice  up    dorm none     none     y
0/0/1:15        06  isdn-voice  up    dorm none     none     y
0/0/1:15        07  isdn-voice  up    dorm none     none     y
0/0/1:15        08  isdn-voice  up    dorm none     none     y
0/0/1:15        09  isdn-voice  up    dorm none     none     y
0/0/1:15        10  isdn-voice  up    dorm none     none     y
0/0/1:15        11  isdn-voice  up    dorm none     none     y
0/0/1:15        12  isdn-voice  up    dorm none     none     y
0/0/1:15        13  isdn-voice  up    dorm none     none     y
0/0/1:15        14  isdn-voice  up    dorm none     none     y
0/0/1:15        15  isdn-voice  up    dorm none     none     y
0/0/1:15        17  isdn-voice  up    dorm none     none     y
0/0/1:15        18  isdn-voice  up    dorm none     none     y
0/0/1:15        19  isdn-voice  up    dorm none     none     y
0/0/1:15        20  isdn-voice  up    dorm none     none     y
0/0/1:15        21  isdn-voice  up    dorm none     none     y
0/0/1:15        22  isdn-voice  up    dorm none     none     y
0/0/1:15        23  isdn-voice  up    dorm none     none     y
0/0/1:15        24  isdn-voice  up    dorm none     none     y
0/0/1:15        25  isdn-voice  up    dorm none     none     y
0/0/1:15        26  isdn-voice  up    dorm none     none     y
0/0/1:15        27  isdn-voice  up    dorm none     none     y
0/0/1:15        28  isdn-voice  up    dorm none     none     y
0/0/1:15        29  isdn-voice  up    dorm none     none     y
0/0/1:15        30  isdn-voice  up    dorm none     none     y
0/0/1:15        31  isdn-voice  up    dorm none     none     y
50/0/1          1      efxs     up    up   on-hook  idle     y
50/0/2          1      efxs     up    up   on-hook  idle     y
50/0/3          1      efxs     up    up   on-hook  idle     y
50/0/4          1      efxs     up    up   on-hook  idle     y
50/0/5          1      efxs     up    up   on-hook  idle     y
50/0/6          1      efxs     up    up   on-hook  idle     y
50/0/7          1      efxs     up    up   on-hook  idle     y
50/0/8          1      efxs     up    up   on-hook  idle     y
50/0/9          1      efxs     up    up   on-hook  idle     y
50/0/10         1      efxs     up    up   on-hook  idle     y
50/0/11         1      efxs     up    up   on-hook  idle     y
50/0/12         1      efxs     up    up   on-hook  idle     y
50/0/13         1      efxs     up    up   on-hook  idle     y
50/0/14         1      efxs     up    up   on-hook  idle     y
50/0/15         1      efxs     up    up   on-hook  idle     y
50/0/16         1      efxs     up    up   on-hook  idle     y
50/0/17         1      efxs     up    up   on-hook  idle     y
50/0/18         1      efxs     up    up   on-hook  idle     y
50/0/19         1      efxs     up    up   on-hook  idle     y
50/0/20         1      efxs     up    up   on-hook  idle     y
50/0/21         1      efxs     up    up   on-hook  idle     y
50/0/22         1      efxs     up    up   on-hook  idle     y
50/0/23         1      efxs     up    up   on-hook  idle     y
50/0/24         1      efxs     up    up   on-hook  idle     y
50/0/25         1      efxs     up    up   on-hook  idle     y
50/0/26         1      efxs     up    up   on-hook  idle     y
50/0/27         1      efxs     up    up   on-hook  idle     y
50/0/28         1      efxs     up    up   on-hook  idle     y
50/0/29         1      efxs     up    up   on-hook  idle     y
50/0/30         1      efxs     up    up   on-hook  idle     y
50/0/31         1      efxs     up    up   on-hook  idle     y
50/0/32         1      efxs     up    up   on-hook  idle     y
50/0/33         1      efxs     up    up   on-hook  idle     y
50/0/34         1      efxs     up    up   on-hook  idle     y
50/0/35         1      efxs     up    up   on-hook  idle     y
50/0/36         1      efxs     up    up   on-hook  idle     y
50/0/37         1      efxs     up    up   on-hook  idle     y
50/0/38         1      efxs     up    up   on-hook  idle     y
50/0/39         1      efxs     up    up   on-hook  idle     y
50/0/40         1      efxs     up    up   on-hook  idle     y
50/0/41         1      efxs     up    up   on-hook  idle     y
50/0/42         1      efxs     up    up   on-hook  idle     y
50/0/43         1      efxs     up    up   on-hook  idle     y
50/0/44         1      efxs     up    up   on-hook  idle     y
50/0/45         1      efxs     up    up   on-hook  idle     y
50/0/46         1      efxs     up    up   on-hook  idle     y
50/0/47         1      efxs     up    up   on-hook  idle     y
50/0/48         1      efxs     up    up   on-hook  idle     y
50/0/49         1      efxs     up    up   on-hook  idle     y
50/0/50         1      efxs     up    up   on-hook  idle     y
50/0/51         1      efxs     up    up   on-hook  idle     y
50/0/52         1      efxs     up    up   on-hook  idle     y
50/0/53         1      efxs     up    up   on-hook  idle     y
50/0/54         1      efxs     up    up   on-hook  idle     y
50/0/55         1      efxs     up    up   on-hook  idle     y
50/0/56         1      efxs     up    up   on-hook  idle     y
50/0/57         1      efxs     up    up   on-hook  idle     y
50/0/58         1      efxs     up    up   on-hook  idle     y
50/0/59         1      efxs     up    up   on-hook  idle     y
50/0/60         1      efxs     up    up   on-hook  idle     y
50/0/61         1      efxs     up    up   on-hook  idle     y
50/0/62         1      efxs     up    up   on-hook  idle     y
50/0/63         1      efxs     up    up   on-hook  idle     y
50/0/64         1      efxs     up    up   on-hook  idle     y
50/0/65         1      efxs     up    up   on-hook  idle     y
50/0/66         1      efxs     up    up   on-hook  idle     y
50/0/67         1      efxs     up    up   on-hook  idle     y
50/0/68         1      efxs     up    up   on-hook  idle     y
50/0/69         1      efxs     up    up   on-hook  idle     y
50/0/70         1      efxs     up    up   on-hook  idle     y
50/0/71         1      efxs     up    up   on-hook  idle     y
50/0/72         1      efxs     up    up   on-hook  idle     y
50/0/73         1      efxs     up    up   on-hook  idle     y
50/0/74         1      efxs     up    up   on-hook  idle     y
50/0/75         1      efxs     up    up   on-hook  idle     y
50/0/76         1      efxs     up    up   on-hook  idle     y
50/0/77         1      efxs     up    up   on-hook  idle     y
50/0/78         1      efxs     up    up   on-hook  idle     y
50/0/79         1      efxs     up    up   on-hook  idle     y
50/0/80         1      efxs     up    up   on-hook  idle     y
50/0/81         1      efxs     up    up   on-hook  idle     y
50/0/82         1      efxs     up    up   on-hook  idle     y
50/0/83         1      efxs     up    up   on-hook  idle     y
50/0/84         1      efxs     up    up   on-hook  idle     y
50/0/85         1      efxs     up    up   on-hook  idle     y
50/0/86         1      efxs     up    up   on-hook  idle     y
50/0/87         1      efxs     up    up   on-hook  idle     y
50/0/88         1      efxs     up    up   on-hook  idle     y
50/0/89         1      efxs     up    up   on-hook  idle     y
50/0/90         1      efxs     up    up   on-hook  idle     y
50/0/91         1      efxs     up    up   on-hook  idle     y
50/0/92         1      efxs     up    up   on-hook  idle     y
50/0/93         1      efxs     up    up   on-hook  idle     y
50/0/94         1      efxs     up    up   on-hook  idle     y
50/0/95         1      efxs     up    up   on-hook  idle     y
50/0/96         1      efxs     up    up   on-hook  idle     y
50/0/97         1      efxs     up    up   on-hook  idle     y
50/0/98         1      efxs     up    up   on-hook  idle     y
50/0/99         1      efxs     up    up   on-hook  idle     y
50/0/100        1      efxs     up    up   on-hook  idle     y
50/0/101        1      efxs     up    up   on-hook  idle     y
50/0/102        1      efxs     up    up   on-hook  idle     y
50/0/103        1      efxs     up    up   on-hook  idle     y
50/0/104        1      efxs     up    up   on-hook  idle     y
50/0/105        1      efxs     up    up   on-hook  idle     y
50/0/106        1      efxs     up    up   on-hook  idle     y
50/0/107        1      efxs     up    up   on-hook  idle     y
50/0/108        1      efxs     up    up   on-hook  idle     y
50/0/109        1      efxs     up    up   on-hook  idle     y
50/0/110        1      efxs     up    up   on-hook  idle     y
50/0/111        1      efxs     up    up   on-hook  idle     y
50/0/112        1      efxs     up    up   on-hook  idle     y
50/0/113        1      efxs     up    up   on-hook  idle     y
50/0/114        1      efxs     up    up   on-hook  idle     y
50/0/115        1      efxs     up    up   on-hook  idle     y
50/0/116        1      efxs     up    up   on-hook  idle     y
50/0/117        1      efxs     up    up   on-hook  idle     y
50/0/118        1      efxs     up    up   on-hook  idle     y
50/0/119        1      efxs     up    up   on-hook  idle     y
50/0/120        1      efxs     up    up   on-hook  idle     y
50/0/121        1      efxs     up    up   on-hook  idle     y
50/0/122        1      efxs     up    up   on-hook  idle     y
50/0/123        1      efxs     up    up   on-hook  idle     y
50/0/124        1      efxs     up    up   on-hook  idle     y
50/0/125        1      efxs     up    up   on-hook  idle     y
50/0/126        1      efxs     up    up   on-hook  idle     y
50/0/127        1      efxs     up    up   on-hook  idle     y
50/0/128        1      efxs     up    up   on-hook  idle     y
50/0/129        1      efxs     up    up   on-hook  idle     y
50/0/130        1      efxs     up    up   on-hook  idle     y
50/0/131        1      efxs     up    up   on-hook  idle     y
50/0/132        1      efxs     up    up   on-hook  idle     y
50/0/133        1      efxs     up    up   on-hook  idle     y
50/0/134        1      efxs     up    up   on-hook  idle     y
50/0/135        1      efxs     up    up   on-hook  idle     y
50/0/136        1      efxs     up    up   on-hook  idle     y
50/0/137        1      efxs     up    up   on-hook  idle     y
50/0/138        1      efxs     up    up   on-hook  idle     y
50/0/139        1      efxs     up    up   on-hook  idle     y
50/0/140        1      efxs     up    up   on-hook  idle     y
50/0/141        1      efxs     up    up   on-hook  idle     y
50/0/142        1      efxs     up    up   on-hook  idle     y
50/0/143        1      efxs     up    up   on-hook  idle     y
50/0/144        1      efxs     up    up   on-hook  idle     y
50/0/145        1      efxs     up    up   on-hook  idle     y
50/0/146        1      efxs     up    up   on-hook  idle     y
50/0/147        1      efxs     up    up   on-hook  idle     y
50/0/148        1      efxs     up    up   on-hook  idle     y
50/0/149        1      efxs     up    up   on-hook  idle     y
50/0/150        1      efxs     up    up   on-hook  idle     y
50/0/151        1      efxs     up    up   on-hook  idle     y
50/0/152        1      efxs     up    up   on-hook  idle     y
50/0/153        1      efxs     up    up   on-hook  idle     y
50/0/154        1      efxs     up    up   on-hook  idle     y
50/0/155        1      efxs     up    up   on-hook  idle     y
50/0/156        1      efxs     up    up   on-hook  idle     y
50/0/157        1      efxs     up    up   on-hook  idle     y
50/0/158        1      efxs     up    up   on-hook  idle     y
50/0/159        1      efxs     up    up   on-hook  idle     y
50/0/160        1      efxs     up    up   on-hook  idle     y
50/0/161        1      efxs     up    up   on-hook  idle     y
50/0/162        1      efxs     up    up   on-hook  idle     y
50/0/163        1      efxs     up    up   on-hook  idle     y
50/0/164        1      efxs     up    up   on-hook  idle     y
50/0/165        1      efxs     up    up   on-hook  idle     y
50/0/166        1      efxs     up    up   on-hook  idle     y
50/0/167        1      efxs     up    up   on-hook  idle     y
50/0/168        1      efxs     up    up   on-hook  idle     y
50/0/169        1      efxs     up    up   on-hook  idle     y
50/0/170        1      efxs     up    up   on-hook  idle     y
50/0/171        1      efxs     up    up   on-hook  idle     y
50/0/172        1      efxs     up    up   on-hook  idle     y
50/0/173        1      efxs     up    up   on-hook  idle     y
50/0/174        1      efxs     up    up   on-hook  idle     y
50/0/175        1      efxs     up    up   on-hook  idle     y
50/0/176        1      efxs     up    up   on-hook  idle     y
50/0/177        1      efxs     up    up   on-hook  idle     y
50/0/178        1      efxs     up    up   on-hook  idle     y
50/0/179        1      efxs     up    up   on-hook  idle     y
50/0/180        1      efxs     up    up   on-hook  idle     y
50/0/181        1      efxs     up    up   on-hook  idle     y
50/0/182        1      efxs     up    up   on-hook  idle     y
50/0/183        1      efxs     up    up   on-hook  idle     y
50/0/184        1      efxs     up    up   on-hook  idle     y
50/0/185        1      efxs     up    up   on-hook  idle     y
50/0/186        1      efxs     up    up   on-hook  idle     y
50/0/187        1      efxs     up    up   on-hook  idle     y
50/0/188        1      efxs     up    up   on-hook  idle     y
50/0/189        1      efxs     up    up   on-hook  idle     y
50/0/190        1      efxs     up    up   on-hook  idle     y
50/0/191        1      efxs     up    up   on-hook  idle     y
50/0/192        1      efxs     up    up   on-hook  idle     y
50/0/193        1      efxs     up    up   on-hook  idle     y
50/0/194        1      efxs     up    up   on-hook  idle     y
50/0/195        1      efxs     up    up   on-hook  idle     y
50/0/196        1      efxs     up    up   on-hook  idle     y
50/0/197        1      efxs     up    up   on-hook  idle     y
50/0/198        1      efxs     up    up   on-hook  idle     y
50/0/199        1      efxs     up    up   on-hook  idle     y
50/0/200        1      efxs     up    up   on-hook  idle     y
50/0/201        1      efxs     up    up   on-hook  idle     y
50/0/202        1      efxs     up    up   on-hook  idle     y
50/0/203        1      efxs     up    up   on-hook  idle     y
50/0/204        1      efxs     up    up   on-hook  idle     y
50/0/205        1      efxs     up    up   on-hook  idle     y
50/0/206        1      efxs     up    up   on-hook  idle     y
50/0/207        1      efxs     up    up   on-hook  idle     y
50/0/208        1      efxs     up    up   on-hook  idle     y
50/0/209        1      efxs     up    up   on-hook  idle     y
50/0/210        1      efxs     up    up   on-hook  idle     y
50/0/211        1      efxs     up    up   on-hook  idle     y
50/0/212        1      efxs     up    up   on-hook  idle     y
50/0/213        1      efxs     up    up   on-hook  idle     y
50/0/214        1      efxs     up    up   on-hook  idle     y
50/0/215        1      efxs     up    up   on-hook  idle     y
50/0/216        1      efxs     up    up   on-hook  idle     y
50/0/217        1      efxs     up    up   on-hook  idle     y
50/0/218        1      efxs     up    up   on-hook  idle     y
50/0/219        1      efxs     up    up   on-hook  idle     y
50/0/220        1      efxs     up    up   on-hook  idle     y
50/0/221        1      efxs     up    up   on-hook  idle     y
50/0/222        1      efxs     up    up   on-hook  idle     y
50/0/223        1      efxs     up    up   on-hook  idle     y
50/0/224        1      efxs     up    up   on-hook  idle     y
50/0/225        1      efxs     up    up   on-hook  idle     y
50/0/226        1      efxs     up    up   on-hook  idle     y
50/0/227        1      efxs     up    up   on-hook  idle     y
50/0/228        1      efxs     up    up   on-hook  idle     y
50/0/229        1      efxs     up    up   on-hook  idle     y
50/0/230        1      efxs     up    up   on-hook  idle     y
50/0/231        1      efxs     up    up   on-hook  idle     y
50/0/232        1      efxs     up    up   on-hook  idle     y
50/0/233        1      efxs     up    up   on-hook  idle     y
50/0/234        1      efxs     up    up   on-hook  idle     y
50/0/235        1      efxs     up    up   on-hook  idle     y
50/0/236        1      efxs     up    up   on-hook  idle     y
50/0/237        1      efxs     up    up   on-hook  idle     y
50/0/238        1      efxs     up    up   on-hook  idle     y
50/0/239        1      efxs     up    up   on-hook  idle     y
50/0/240        1      efxs     up    up   on-hook  idle     y
50/0/241        1      efxs     up    up   on-hook  idle     y
50/0/242        1      efxs     up    up   on-hook  idle     y
50/0/243        1      efxs     up    up   on-hook  idle     y
50/0/244        1      efxs     up    up   on-hook  idle     y
50/0/245        1      efxs     up    up   on-hook  idle     y
50/0/246        1      efxs     up    up   on-hook  idle     y
50/0/247        1      efxs     up    up   on-hook  idle     y
50/0/248        1      efxs     up    up   on-hook  idle     y
50/0/249        1      efxs     up    up   on-hook  idle     y
50/0/250        1      efxs     up    up   on-hook  idle     y
50/0/251        1      efxs     up    up   on-hook  idle     y
50/0/252        1      efxs     up    up   on-hook  idle     y
50/0/253        1      efxs     up    up   on-hook  idle     y
50/0/254        1      efxs     up    up   on-hook  idle     y
50/0/255        1      efxs     up    up   on-hook  idle     y
50/0/256        1      efxs     up    up   on-hook  idle     y
50/0/257        1      efxs     up    up   on-hook  idle     y
50/0/258        1      efxs     up    up   on-hook  idle     y
50/0/259        1      efxs     up    up   on-hook  idle     y
50/0/260        1      efxs     up    up   on-hook  idle     y
50/0/261        1      efxs     up    up   on-hook  idle     y
50/0/262        1      efxs     up    up   on-hook  idle     y
50/0/263        1      efxs     up    up   on-hook  idle     y
50/0/264        1      efxs     up    up   on-hook  idle     y
50/0/265        1      efxs     up    up   on-hook  idle     y
50/0/266        1      efxs     up    up   on-hook  idle     y
50/0/267        1      efxs     up    up   on-hook  idle     y
50/0/268        1      efxs     up    up   on-hook  idle     y
50/0/269        1      efxs     up    up   on-hook  idle     y
50/0/270        1      efxs     up    up   on-hook  idle     y
50/0/271        1      efxs     up    up   on-hook  idle     y
50/0/272        1      efxs     up    up   on-hook  idle     y
50/0/273        1      efxs     up    up   on-hook  idle     y
50/0/274        1      efxs     up    up   on-hook  idle     y
50/0/275        1      efxs     up    up   on-hook  idle     y
50/0/276        1      efxs     up    up   on-hook  idle     y
50/0/277        1      efxs     up    up   on-hook  idle     y
50/0/278        1      efxs     up    up   on-hook  idle     y
50/0/279        1      efxs     up    up   on-hook  idle     y
50/0/280        1      efxs     up    up   on-hook  idle     y
50/0/281        1      efxs     up    up   on-hook  idle     y
50/0/282        1      efxs     up    up   on-hook  idle     y
50/0/283        1      efxs     up    up   on-hook  idle     y
50/0/284        1      efxs     up    up   on-hook  idle     y
50/0/285        1      efxs     up    up   on-hook  idle     y
50/0/286        1      efxs     up    up   on-hook  idle     y
50/0/287        1      efxs     up    up   on-hook  idle     y
50/0/288        1      efxs     up    up   on-hook  idle     y
50/0/289        1      efxs     up    up   on-hook  idle     y
50/0/290        1      efxs     up    up   on-hook  idle     y
50/0/291        1      efxs     up    up   on-hook  idle     y
50/0/292        1      efxs     up    up   on-hook  idle     y
50/0/293        1      efxs     up    up   on-hook  idle     y
50/0/294        1      efxs     up    up   on-hook  idle     y
50/0/295        1      efxs     up    up   on-hook  idle     y
50/0/296        1      efxs     up    up   on-hook  idle     y
50/0/297        1      efxs     up    up   on-hook  idle     y
50/0/298        1      efxs     up    up   on-hook  idle     y
50/0/299        1      efxs     up    up   on-hook  idle     y
50/0/300        1      efxs     up    up   on-hook  idle     y
50/0/301        1      efxs     up    up   on-hook  idle     y
50/0/302        1      efxs     up    up   on-hook  idle     y
50/0/303        1      efxs     up    up   on-hook  idle     y
50/0/304        1      efxs     up    up   on-hook  idle     y
50/0/305        1      efxs     up    up   on-hook  idle     y
50/0/306        1      efxs     up    up   on-hook  idle     y
50/0/307        1      efxs     up    up   on-hook  idle     y
50/0/308        1      efxs     up    up   on-hook  idle     y
50/0/309        1      efxs     up    up   on-hook  idle     y
50/0/310        1      efxs     up    up   on-hook  idle     y
50/0/311        1      efxs     up    up   on-hook  idle     y
50/0/312        1      efxs     up    up   on-hook  idle     y
50/0/313        1      efxs     up    up   on-hook  idle     y
50/0/314        1      efxs     up    up   on-hook  idle     y
50/0/315        1      efxs     up    up   on-hook  idle     y
50/0/316        1      efxs     up    up   on-hook  idle     y
50/0/317        1      efxs     up    up   on-hook  idle     y
50/0/318        1      efxs     up    up   on-hook  idle     y
50/0/319        1      efxs     up    up   on-hook  idle     y
50/0/320        1      efxs     up    up   on-hook  idle     y
50/0/321        1      efxs     up    up   on-hook  idle     y
50/0/322        1      efxs     up    up   on-hook  idle     y
50/0/323        1      efxs     up    up   on-hook  idle     y
50/0/324        1      efxs     up    up   on-hook  idle     y
50/0/325        1      efxs     up    up   on-hook  idle     y
50/0/326        1      efxs     up    up   on-hook  idle     y
50/0/327        1      efxs     up    up   on-hook  idle     y
50/0/328        1      efxs     up    up   on-hook  idle     y
50/0/329        1      efxs     up    up   on-hook  idle     y
50/0/330        1      efxs     up    up   on-hook  idle     y
50/0/331        1      efxs     up    up   on-hook  idle     y
50/0/332        1      efxs     up    up   on-hook  idle     y
50/0/333        1      efxs     up    up   on-hook  idle     y
50/0/334        1      efxs     up    up   on-hook  idle     y
50/0/335        1      efxs     up    up   on-hook  idle     y
50/0/336        1      efxs     up    up   on-hook  idle     y
50/0/337        1      efxs     up    up   on-hook  idle     y
50/0/338        1      efxs     up    up   on-hook  idle     y
50/0/339        1      efxs     up    up   on-hook  idle     y
50/0/340        1      efxs     up    up   on-hook  idle     y
50/0/341        1      efxs     up    up   on-hook  idle     y
50/0/342        1      efxs     up    up   on-hook  idle     y
50/0/343        1      efxs     up    up   on-hook  idle     y
50/0/344        1      efxs     up    up   on-hook  idle     y
50/0/345        1      efxs     up    up   on-hook  idle     y
50/0/346        1      efxs     up    up   on-hook  idle     y
50/0/347        1      efxs     up    up   on-hook  idle     y
50/0/348        1      efxs     up    up   on-hook  idle     y
50/0/349        1      efxs     up    up   on-hook  idle     y
50/0/350        1      efxs     up    up   on-hook  idle     y
50/0/351        1      efxs     up    up   on-hook  idle     y
50/0/352        1      efxs     up    up   on-hook  idle     y
50/0/353        1      efxs     up    up   on-hook  idle     y
50/0/354        1      efxs     up    up   on-hook  idle     y
50/0/355        1      efxs     up    up   on-hook  idle     y
50/0/356        1      efxs     up    up   on-hook  idle     y
50/0/357        1      efxs     up    up   on-hook  idle     y
50/0/358        1      efxs     up    up   on-hook  idle     y
50/0/359        1      efxs     up    up   on-hook  idle     y
50/0/360        1      efxs     up    up   on-hook  idle     y
50/0/361        1      efxs     up    up   on-hook  idle     y
50/0/362        1      efxs     up    up   on-hook  idle     y
50/0/363        1      efxs     up    up   on-hook  idle     y
50/0/364        1      efxs     up    up   on-hook  idle     y
50/0/365        1      efxs     up    up   on-hook  idle     y
50/0/366        1      efxs     up    up   on-hook  idle     y
50/0/367        1      efxs     up    up   on-hook  idle     y
50/0/368        1      efxs     up    up   on-hook  idle     y
50/0/369        1      efxs     up    up   on-hook  idle     y
50/0/370        1      efxs     up    up   on-hook  idle     y
50/0/371        1      efxs     up    up   on-hook  idle     y
50/0/372        1      efxs     up    up   on-hook  idle     y
50/0/373        1      efxs     up    up   on-hook  idle     y
50/0/374        1      efxs     up    up   on-hook  idle     y
50/0/375        1      efxs     up    up   on-hook  idle     y
50/0/376        1      efxs     up    up   on-hook  idle     y
50/0/377        1      efxs     up    up   on-hook  idle     y
50/0/378        1      efxs     up    up   on-hook  idle     y
50/0/379        1      efxs     up    up   on-hook  idle     y
50/0/380        1      efxs     up    up   on-hook  idle     y
50/0/381        1      efxs     up    up   on-hook  idle     y
50/0/382        1      efxs     up    up   on-hook  idle     y
50/0/383        1      efxs     up    up   on-hook  idle     y
50/0/384        1      efxs     up    up   on-hook  idle     y
50/0/385        1      efxs     up    up   on-hook  idle     y
50/0/386        1      efxs     up    up   on-hook  idle     y
50/0/387        1      efxs     up    up   on-hook  idle     y
50/0/388        1      efxs     up    up   on-hook  idle     y
50/0/389        1      efxs     up    up   on-hook  idle     y
50/0/390        1      efxs     up    up   on-hook  idle     y
50/0/391        1      efxs     up    up   on-hook  idle     y
50/0/392        1      efxs     up    up   on-hook  idle     y
50/0/393        1      efxs     up    up   on-hook  idle     y
50/0/394        1      efxs     up    up   on-hook  idle     y
50/0/395        1      efxs     up    up   on-hook  idle     y
50/0/396        1      efxs     up    up   on-hook  idle     y
50/0/397        1      efxs     up    up   on-hook  idle     y
50/0/398        1      efxs     up    up   on-hook  idle     y
50/0/399        1      efxs     up    up   on-hook  idle     y
50/0/400        1      efxs     up    up   on-hook  idle     y
50/0/401        1      efxs     up    up   on-hook  idle     y
50/0/402        1      efxs     up    up   on-hook  idle     y
50/0/403        1      efxs     up    up   on-hook  idle     y
50/0/404        1      efxs     up    up   on-hook  idle     y
50/0/405        1      efxs     up    up   on-hook  idle     y
50/0/406        1      efxs     up    up   on-hook  idle     y
50/0/407        1      efxs     up    up   on-hook  idle     y
50/0/408        1      efxs     up    up   on-hook  idle     y
50/0/409        1      efxs     up    up   on-hook  idle     y
50/0/410        1      efxs     up    up   on-hook  idle     y
50/0/411        1      efxs     up    up   on-hook  idle     y
50/0/412        1      efxs     up    up   on-hook  idle     y
50/0/413        1      efxs     up    up   on-hook  idle     y
50/0/414        1      efxs     up    up   on-hook  idle     y
50/0/415        1      efxs     up    up   on-hook  idle     y
50/0/416        1      efxs     up    up   on-hook  idle     y
50/0/417        1      efxs     up    up   on-hook  idle     y
50/0/418        1      efxs     up    up   on-hook  idle     y
50/0/419        1      efxs     up    up   on-hook  idle     y
50/0/420        1      efxs     up    up   on-hook  idle     y
50/0/421        1      efxs     up    up   on-hook  idle     y
50/0/422        1      efxs     up    up   on-hook  idle     y
50/0/423        1      efxs     up    up   on-hook  idle     y
50/0/424        1      efxs     up    up   on-hook  idle     y
50/0/425        1      efxs     up    up   on-hook  idle     y
50/0/426        1      efxs     up    up   on-hook  idle     y
50/0/427        1      efxs     up    up   on-hook  idle     y
50/0/428        1      efxs     up    up   on-hook  idle     y
50/0/429        1      efxs     up    up   on-hook  idle     y
50/0/430        1      efxs     up    up   on-hook  idle     y
50/0/431        1      efxs     up    up   on-hook  idle     y
50/0/432        1      efxs     up    up   on-hook  idle     y
50/0/433        1      efxs     up    up   on-hook  idle     y
50/0/434        1      efxs     up    up   on-hook  idle     y
50/0/435        1      efxs     up    up   on-hook  idle     y
50/0/436        1      efxs     up    up   on-hook  idle     y
50/0/437        1      efxs     up    up   on-hook  idle     y
50/0/438        1      efxs     up    up   on-hook  idle     y
50/0/439        1      efxs     up    up   on-hook  idle     y
50/0/440        1      efxs     up    up   on-hook  idle     y
50/0/441        1      efxs     up    up   on-hook  idle     y
50/0/442        1      efxs     up    up   on-hook  idle     y
50/0/443        1      efxs     up    up   on-hook  idle     y
50/0/444        1      efxs     up    up   on-hook  idle     y
50/0/445        1      efxs     up    up   on-hook  idle     y
50/0/446        1      efxs     up    up   on-hook  idle     y
50/0/447        1      efxs     up    up   on-hook  idle     y
50/0/448        1      efxs     up    up   on-hook  idle     y
50/0/449        1      efxs     up    up   on-hook  idle     y
50/0/450        1      efxs     up    up   on-hook  idle     y
50/0/451        1      efxs     up    up   on-hook  idle     y
50/0/452        1      efxs     up    up   on-hook  idle     y
50/0/453        1      efxs     up    up   on-hook  idle     y
50/0/454        1      efxs     up    up   on-hook  idle     y
50/0/455        1      efxs     up    up   on-hook  idle     y
50/0/456        1      efxs     up    up   on-hook  idle     y
50/0/457        1      efxs     up    up   on-hook  idle     y
50/0/458        1      efxs     up    up   on-hook  idle     y
50/0/459        1      efxs     up    up   on-hook  idle     y
50/0/460        1      efxs     up    up   on-hook  idle     y
50/0/461        1      efxs     up    up   on-hook  idle     y
50/0/462        1      efxs     up    up   on-hook  idle     y
50/0/463        1      efxs     up    up   on-hook  idle     y
50/0/464        1      efxs     up    up   on-hook  idle     y
50/0/465        1      efxs     up    up   on-hook  idle     y
50/0/466        1      efxs     up    up   on-hook  idle     y
50/0/467        1      efxs     up    up   on-hook  idle     y
50/0/468        1      efxs     up    up   on-hook  idle     y
50/0/469        1      efxs     up    up   on-hook  idle     y
50/0/470        1      efxs     up    up   on-hook  idle     y
50/0/471        1      efxs     up    up   on-hook  idle     y
50/0/472        1      efxs     up    up   on-hook  idle     y
50/0/473        1      efxs     up    up   on-hook  idle     y
50/0/474        1      efxs     up    up   on-hook  idle     y
50/0/475        1      efxs     up    up   on-hook  idle     y
50/0/476        1      efxs     up    up   on-hook  idle     y
50/0/477        1      efxs     up    up   on-hook  idle     y
50/0/478        1      efxs     up    up   on-hook  idle     y
50/0/479        1      efxs     up    up   on-hook  idle     y
50/0/480        1      efxs     up    up   on-hook  idle     y
50/0/481        1      efxs     up    up   on-hook  idle     y
50/0/482        1      efxs     up    up   on-hook  idle     y
50/0/483        1      efxs     up    up   on-hook  idle     y
50/0/484        1      efxs     up    up   on-hook  idle     y
50/0/485        1      efxs     up    up   on-hook  idle     y
50/0/486        1      efxs     up    up   on-hook  idle     y
50/0/487        1      efxs     up    up   on-hook  idle     y
50/0/488        1      efxs     up    up   on-hook  idle     y
50/0/489        1      efxs     up    up   on-hook  idle     y
50/0/490        1      efxs     up    up   on-hook  idle     y
50/0/491        1      efxs     up    up   on-hook  idle     y
50/0/492        1      efxs     up    up   on-hook  idle     y
50/0/493        1      efxs     up    up   on-hook  idle     y
50/0/494        1      efxs     up    up   on-hook  idle     y
50/0/495        1      efxs     up    up   on-hook  idle     y
50/0/496        1      efxs     up    up   on-hook  idle     y
50/0/497        1      efxs     up    up   on-hook  idle     y
50/0/498        1      efxs     up    up   on-hook  idle     y
50/0/499        1      efxs     up    up   on-hook  idle     y
50/0/500        1      efxs     up    up   on-hook  idle     y
PWR FAILOVER PORT        PSTN FAILOVER PORT
R1#
R1#
R1#
R1#sh run
Building configuration...
Current configuration : 10596 bytes
! No configuration change since last restart
version 15.1
service password-encryption
hostname R1
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 20000000
no logging console
enable secret 5 $1$hCcX$ve2XFpAjgCu5CMoiqpjRj0
aaa new-model
aaa authentication banner ^CWarning - Unauthorized use is prohibited !^C
aaa authentication fail-message ^CFailed login - user not authorized !!! Try again.^C
aaa authentication login default group tacacs+ local
aaa authentication enable default none
aaa authentication dot1x default group radius
aaa authorization config-commands
aaa authorization exec default group tacacs+ local
aaa authorization commands 0 default group tacacs+ local
aaa authorization commands 1 default group tacacs+ local
aaa authorization commands 15 default group tacacs+ local
aaa authorization network default group radius
aaa accounting exec default
action-type start-stop
group tacacs+
aaa accounting commands 1 default
action-type stop-only
group tacacs+
aaa accounting commands 15 default
group tacacs+
aaa accounting system default
group radius
aaa session-id common
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
no ipv6 cef
ip source-route
ip cef
ip multicast-routing
ip domain name yourdomain.com
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-2039684814
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2039684814
revocation-check none
rsakeypair TP-self-signed-2039684814
crypto pki certificate chain TP-self-signed-2039684814
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32303339 36383438 3134301E 170D3131 31323038 31343335
  30365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 30333936
  38343831 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B0FC 587C331A 97B082C0 2B1EE1DD 8B2BDD54 31BE2A1E C1D0931E A4A90C45
  794C33B0 98182681 8C13540B 32546224 6B5E383E CDDCCBF0 D0442522 ECDB983F
  E478D67D 777E1EA6 2F1D0304 0E2F03C1 4EEB9A9E B1565046 04C2727D 53C241BF
  C6CAD3BC B55BABF5 E5D8EB40 BA97B91B 2A57314F 2144E3F7 7E402C1C 04D0819E
  1F0B0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 149192CF 3FF2E174 770DA425 B4045862 F546A1C8 16301D06
  03551D0E 04160414 9192CF3F F2E17477 0DA425B4 045862F5 46A1C816 300D0609
  2A864886 F70D0101 05050003 8181009D 1A62A452 2D89BBB1 CD0A468F E16982BC
  05FFAA1C AD9E01C5 14410756 34F221E6 E847C453 EF5832F6 159D907E 6D75D6F1
  034DA0C0 4FDBE721 CAB54D1B 7AB2AF21 DA1CA8F3 AFC9CF95 E6CF817D 202E899E
  980AB170 825C766F 76F06217 498052D4 C67DB9C1 59A91FFC E45B43A0 B45B86A5
  873AB36B D63E9EB8 5BDE9666 02DFC1
        quit
voice-card 0
dsp services dspfarm
voice call send-alert
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
no ip address trusted authenticate
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729br8
codec preference 4 g729r8
voice class h323 1
  h225 timeout tcp establish 5
voice translation-rule 1
rule 1 // /0/ type unknown unknown
rule 2 // /0/ type subscriber subscriber
rule 3 // /00/ type national national
rule 4 // /000/ type international international
voice translation-rule 2
rule 1 /^3096/ //
rule 2 /^3095/ /49365/
rule 3 /^8043306/ //
voice translation-rule 3
rule 1 /^1\(..$\)/ /30961\1/
rule 2 /^3\(..$\)/ /30963\1/
rule 3 /^4\(..$\)/ /30964\1/
voice translation-rule 4
rule 1 /^493658\(..$\)/ /30958\1/
rule 2 /^493659\(..$\)/ /30959\1/
voice translation-profile FromPSTN-PRI0
translate called 3
voice translation-profile FromPSTN-PRI1
translate called 4
voice translation-profile ToCCM
translate calling 1
voice translation-profile ToPSTN
translate calling 2
license udi pid C3900-SPE100/K9 sn FOC15463NKL
hw-module pvdm 0/0
hw-module pvdm 0/1
username croot privilege 15 secret 5 $1$atsJ$U4HDlVJ7O7KSosND/hqTO1
username hbasadmin privilege 15 password 7 133D1A1403555C0061372D30
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 0/0/1
framing NO-CRC4
ip ftp username switchadmin
ip ftp password 7 0836455E1B16554F5C
ip ssh time-out 100
ip ssh authentication-retries 2
interface Loopback0
description Loopback Interface for Multicast MoH
ip address 1.1.1.1 255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Bangalore LAN
ip address 10.90.70.2 255.255.254.0
ip pim sparse-mode
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.90.70.2
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
interface Serial0/0/1:15
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.90.70.1
logging trap notifications
logging 10.10.23.10
access-list 23 permit 10.10.10.0 0.0.0.7
nls resp-timeout 1
cpd cr-id 1
snmp-server community spiderman RO
snmp-server community hirma RW
snmp-server community spidermansnmp RW
snmp-server location IDC_Bangalore
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server host 10.16.11.254 version 2c spiderman
snmp-server host 172.16.2.2 spiderman
tacacs-server host 172.16.3.126
tacacs-server host 172.16.65.33
tacacs-server host 10.65.16.72
tacacs-server directed-request
tacacs-server key 7 03206A333F35151A405803
control-plane
voice-port 0/0/0:15
input gain 3
echo-cancel coverage 32
no vad
no comfort-noise
voice-port 0/0/1:15
input gain 3
no vad
no comfort-noise
ccm-manager music-on-hold
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 172.16.2.204 identifier 1 version 7.0
sccp ccm 172.16.2.199 identifier 2 version 7.0
sccp ip precedence 3
sccp
sccp ccm group 1
description Associate Media Ressource (Conf & XCode) to CCM and SRST
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register XCD_VGIDCBLR
associate profile 2 register CFB_VGIDCBLR
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 15
dspfarm profile 1 transcode
description Hadware Transcoding located at BLR : 4 sessions
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729r8
maximum sessions 15
associate application SCCP
dspfarm profile 2 conference
description Hadware Conferencing located at BLR : 2 Conferences
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 10
dial-peer voice 1001 pots
description Route Pattern 0T to PSTN via E1 0/0/0
translation-profile incoming FromPSTN-PRI0
translation-profile outgoing ToPSTN
destination-pattern 0T
progress_ind alert enable 8
progress_ind progress enable 8
incoming called-number [134]..
fax rate disable
direct-inward-dial
port 0/0/0:15
dial-peer voice 3090 voip
description Route Pattern 309.... to CCM Subscriber 1 with priority 1
translation-profile outgoing ToCCM
preference 1
destination-pattern 309....
progress_ind setup enable 3
modem passthrough nse codec g711ulaw
session target ipv4:172.16.2.204
incoming called-number .
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
fax-relay ecm disable
fax rate disable
no vad
dial-peer voice 3091 voip
description Route Pattern 309.... to CCM Publisher with priority 2
preference 2
session target ipv4:172.16.2.199
voice-class codec 1
voice-class h323 1
fax rate disable
no vad
dial-peer voice 1002 pots
description Route Pattern 9T to PSTN via E1 0/0/1
translation-profile incoming FromPSTN-PRI1
destination-pattern 9T
incoming called-number 49365[89]..
fax rate disable
direct-inward-dial
port 0/0/1:15
gatekeeper
shutdown
call-manager-fallback
max-conferences 6 gain -6
transfer-system full-consult
limit-dn 7940 2
limit-dn 7960 2
ip source-address 10.90.70.2 port 2000
max-ephones 250
max-dn 500
dialplan-pattern 1 309.... extension-length 4
moh MoHulaw.wav
multicast moh 239.1.1.1 port 16384 route 10.90.70.2 1.1.1.1
time-format 24
date-format dd-mm-yy
debug q931
R1#debug isdn q931
debug isdn q931 is              ON.
R1#
Feb 28 12:36:52.536: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x28B1
        Cause i = 0x8090 - Normal call clearing
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Feb 28 12:36:52.540: %ISDN-6-DISCONNECT: Interface Serial0/0/0:16  disconnected from 9167496486 , call lasted 25 seconds
Feb 28 12:36:52.540: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x3D1F
Feb 28 12:36:52.552: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0xA8B1
Feb 28 12:36:52.572: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x28B1
Feb 28 12:36:52.768: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0xD263
        Date/Time i = 0x0E021C1205
                Date (dd-mm-yr)   = 14-02-28
                Time (hr:mnt:sec) = 18:05:10
Feb 28 12:36:52.768: %ISDN-6-CONNECT: Interface Serial0/0/0:1 is now connected to 9741181002 N/A
Feb 28 12:36:52.772: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x5263
Feb 28 12:37:06.388: ISDN Se0/0/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0xD259
        Cause i = 0x809000000000 - Normal call clearing
Feb 28 12:37:06.388: %ISDN-6-DISCONNECT: Interface Serial0/0/1:0  disconnected f
Feb 28 12:37:06.388: ISDN Se0/0/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x525
Feb 28 12:37:06.548: ISDN Se0/0/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref =
Feb 28 12:37:15.836: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x28B2
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839E
                Exclusive, Channel 30
        Calling Party Number i = 0x2181, '8412994112'
                Plan:ISDN, Type:National
        Called Party Number i = 0x81, '354'
                Plan:ISDN, Type:Unknown
        High Layer Compat i = 0x9181
Feb 28 12:37:15.840: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0xA8B2 call                                              User
Feb 28 12:37:15.840: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xA
Feb 28 12:37:16.880: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0xA8
        Progress Ind i = 0x8188 - In-band info or appropriate now available
Feb 28 12:37:21.288: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x28B2
Feb 28 12:37:21.292: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0xA8B2
Feb 28 12:37:21.304: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x28B2
Feb 28 12:38:31.532: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 181
Feb 28 12:38:31.532: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x5265 callID = 0xCA51 switch = primary-net5 interface = User
Feb 28 12:38:31.532: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x5265
                Standard = CCITT
        Channel ID i = 0xA98387
                Exclusive, Channel 7
        Calling Party Number i = 0x0081, '181'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '08800222333'
Feb 28 12:38:31.556: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xD265
        Cause i = 0x82AC - Requested circuit/channel not available
Feb 28 12:38:40.604: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 181
Feb 28 12:38:40.604: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x5266 callID = 0xCA52 switch = primary-net5 interface = User
Feb 28 12:38:40.604: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x5266
                Standard = CCITT
Feb 28 12:38:40.628: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xD266
Feb 28 12:38:44.180: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 179
Feb 28 12:38:44.180: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x5267 callID = 0xCA53 switch = primary-net5 interface = User
Feb 28 12:38:44.180: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x5267
                Standard = CCITT
        Calling Party Number i = 0x0081, '179'
        Called Party Number i = 0x80, '00441926926002'
Feb 28 12:38:44.204: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xD267
Feb 28 12:38:50.720: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0xD246
Feb 28 12:38:50.724: %ISDN-6-DISCONNECT: Interface Serial0/0/0:5  disconnected from 8722207999 , call lasted 582 seconds
Feb 28 12:38:50.724: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0xCA32
Feb 28 12:38:51.164: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x5246
Feb 28 12:38:51.176: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xD246
Feb 28 12:38:51.692: %ISDN-6-DISCONNECT: Interface Serial0/0/0:2  disconnected from 008613510895912 , call lasted 733 seconds
Feb 28 12:38:51.692: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x5239
Feb 28 12:38:51.764: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0xD239
Feb 28 12:38:51.764: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x5239
Feb 28 12:38:53.392: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 391
Feb 28 12:38:53.392: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x5268 callID = 0xCA54 switch = primary-net5 interface = User
Feb 28 12:38:53.392: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x5268
                Standard = CCITT
        Channel ID i = 0xA98383
        Calling Party Number i = 0x0081, '391'
        Called Party Number i = 0x80, '9886374881'
Feb 28 12:38:53.432: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xD268
Feb 28 12:38:53.700: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xD268
Feb 28 12:38:54.456: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0xD268
        Progress Ind i = 0x8488 - In-band info or appropriate now available
        Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info
Feb 28 12:38:58.855: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x5268
Feb 28 12:38:58.943: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0xD268
Feb 28 12:38:58.943: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x5268
Feb 28 12:39:01.639: ISDN Se0/0/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 49365914
Feb 28 12:39:01.639: ISDN Se0/0/1:15 Q931: Sending SETUP  callref = 0x5269 callID = 0xCA55 switch = primary-net5 interface = User
Feb 28 12:39:01.639: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8  callref = 0x5269
                Standard = CCITT
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x0081, '49365914'
        Called Party Number i = 0x80, '9663578020'
Feb 28 12:39:01.723: ISDN Se0/0/1:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xD269
Feb 28 12:39:01.723: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xD269
Feb 28 12:39:05.571: ISDN Se0/0/1:15 Q931: RX <- ALERTING pd = 8  callref = 0xD269
Feb 28 12:39:16.951: ISDN Se0/0/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 49365928
Feb 28 12:39:16.951: ISDN Se0/0/1:15 Q931: Sending SETUP  callref = 0x526A callID = 0xCA56 switch = primary-net5 interface = User
Feb 28 12:39:16.951: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8  callref = 0x526A
                Standard = CCITT
        Channel ID i = 0xA98382
                Exclusive, Channel 2
        Calling Party Number i = 0x0081, '49365928'
        Called Party Number i = 0x80, '9663422511'
Feb 28 12:39:17.027: ISDN Se0/0/1:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xD26A
Feb 28 12:39:17.027: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xD26A
Feb 28 12:39:19.511: ISDN Se0/0/1:15 Q931: RX <- CONNECT pd = 8  callref = 0xD269
        Date/Time i = 0x0E021C120913
                Time (hr:mnt:sec) = 18:09:19
Feb 28 12:39:19.511: %ISDN-6-CONNECT: Interface Serial0/0/1:0 is now connected to 9663578020 N/A
Feb 28 12:39:19.511: ISDN Se0/0/1:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x5269
Feb 28 12:39:20.379: ISDN Se0/0/1:15 Q931: RX <- ALERTING pd = 8  callref = 0xD26A
Feb 28 12:39:28.907: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 391
Feb 28 12:39:28.907: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x526B callID = 0xCA57 switch = primary-net5 interface = User
Feb 28 12:39:28.907: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x526B
                Standard = CCITT
        Called Party Number i = 0x80, '08897859420'
Feb 28 12:39:28.943: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xD26B
Feb 28 12:39:29.223: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xD26B
Feb 28 12:39:32.003: ISDN Se0/0/1:15 Q931: RX <- CONNECT pd = 8  callref = 0xD26A
        Date/Time i = 0x0E021C12091F
                Time (hr:mnt:sec) = 18:09:31
Feb 28 12:39:32.003: %ISDN-6-CONNECT: Interface Serial0/0/1:1 is now connected to 9663422511 N/A
Feb 28 12:39:32.003: ISDN Se0/0/1:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x526A
Feb 28 12:39:33.243: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0xD26B
Feb 28 12:39:47.439: %ISDN-6-DISCONNECT: Interface Serial0/0/1:0  disconnected from 9663578020 , call lasted 27 seconds
Feb 28 12:39:47.439: ISDN Se0/0/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x5269
Feb 28 12:39:47.519: ISDN Se0/0/1:15 Q931: RX <- RELEASE pd = 8  callref = 0xD269
Feb 28 12:39:47.519: ISDN Se0/0/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x5269
Feb 28 12:39:48.007: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0xD26B
        Date/Time i = 0x0E021C1208
                Time (hr:mnt:sec) = 18:08:70
Feb 28 12:39:48.007: %ISDN-6-CONNECT: Interface Serial0/0/0:2 is now connected to 08897859420 N/A
Feb 28 12:39:48.007: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x526B
Feb 28 12:40:07.379: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x28B3
        Sending Complete
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
        Channel ID i = 0xA98386
                Exclusive, Channel 6
        Progress Ind i = 0x8283 - Origination address is non-ISDN
        Calling Party Number i = 0x1183, '4962229488848'
                Plan:ISDN, Type:International
        Called Party Number i = 0x81, '147'
Feb 28 12:40:07.379: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0xA8B3 callID = 0x3D21 switch = primary-net5 interface = User
Feb 28 12:40:07.383: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xA8B3
Feb 28 12:40:08.427: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0xA8B3
Feb 28 12:40:09.367: ISDN Se0/0/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 49365914
Feb 28 12:40:09.367: ISDN Se0/0/1:15 Q931: Sending SETUP  callref = 0x526C callID = 0xCA58 switch = primary-net5 interface = User
Feb 28 12:40:09.367: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8  callref = 0x526C
                Standard = CCITT
Feb 28 12:40:09.451: ISDN Se0/0/1:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xD26C
Feb 28 12:40:09.451: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xD26C
Feb 28 12:40:13.351: ISDN Se0/0/1:15 Q931: RX <- ALERTING pd = 8  callref = 0xD26C
Feb 28 12:40:14.907: ISDN Se0/0/1:15 Q931: RX <- CONNECT pd = 8  callref = 0xD26C
        Date/Time i = 0x0E021C120A0E
                Time (hr:mnt:sec) = 18:10:14
Feb 28 12:40:14.907: %ISDN-6-CONNECT: Interface Serial0/0/1:0 is now connected to 9663578020 N/A
Feb 28 12:40:14.907: ISDN Se0/0/1:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x526C
Feb 28 12:40:16.347: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 177
Feb 28 12:40:16.347: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x526D callID = 0xCA59 switch = primary-net5 interface = User
Feb 28 12:40:16.347: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x526D
                Standard = CCITT
        Calling Party Number i = 0x0081, '177'
        Called Party Number i = 0x80, '9740979030'
Feb 28 12:40:16.371: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xD26D
Feb 28 12:40:17.071: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8  callref = 0xA8B3
Feb 28 12:40:17.103: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x28B3
Feb 28 12:40:17.103: %ISDN-6-CONNECT: Interface Serial0/0/0:5 is now connected to 4962229488848 N/A
Feb 28 12:40:24.291: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 918043306189
Feb 28 12:40:24.295: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x526E callID = 0xCA5A switch = primary-net5 interface = User
Feb 28 12:40:24.295: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x526E
                Standard = CCITT
        Calling Party Number i = 0x0081, '918043306189'
        Called Party Number i = 0x80, '7829729141'
Feb 28 12:40:24.319: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xD26E
Feb 28 12:40:31.047: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 177
Feb 28 12:40:31.047: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x526F callID = 0xCA5B switch = primary-net5 interface = User
Feb 28 12:40:31.047: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x526F
                Standard = CCITT
Feb 28 12:40:31.071: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xD26F
Feb 28 12:40:33.635: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 918043306189
Feb 28 12:40:33.635: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x5270 callID = 0xCA5C switch = primary-net5 interface = User
Feb 28 12:40:33.635: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x5270
                Standard = CCITT
        Called Party Number i = 0x80, '9019969596'
Feb 28 12:40:33.659: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xD270
Feb 28 12:40:37.379: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 177
Feb 28 12:40:37.379: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x5271 callID = 0xCA5D switch = primary-net5 interface = User
Feb 28 12:40:37.379: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x5271
                Standard = CCITT
Feb 28 12:40:37.403: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xD271
Feb 28 12:40:40.623: ISDN Se0/0/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 49365849
Feb 28 12:40:40.623: ISDN Se0/0/1:15 Q931: Sending SETUP  callref = 0x5272 callID = 0xCA5E switch = primary-net5 interface = User
Feb 28 12:40:40.623: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8  callref = 0x5272
                Standard = CCITT
        Calling Party Number i = 0x0081, '49365849'
        Called Party Number i = 0x80, '08067186903'
Feb 28 12:40:40.699: ISDN Se0/0/1:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xD272
Feb 28 12:40:40.699: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xD272
Feb 28 12:40:41.823: ISDN Se0/0/1:15 Q931: RX <- ALERTING pd = 8  callref = 0xD272
        Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Feb 28 12:40:42.399: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x28B4
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98394
                Exclusive, Channel 20
        Calling Party Number i = 0x2183, '8042034399'
        Called Party Number i = 0x81, '300'
Feb 28 12:40:42.399: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0xA8B4 callID = 0x3D22 switch = primary-net5 interface = User
Feb 28 12:40:42.403: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xA8B4
Feb 28 12:40:43.463: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0xA8B4
Feb 28 12:40:45.291: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 177
Feb 28 12:40:45.291: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x5273 callID = 0xCA5F switch = primary-net5 interface = User
Feb 28 12:40:45.291: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x5273
                Standard = CCITT
Feb 28 12:40:45.323: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xD273
R1#
Feb 28 12:40:56.423: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8  callref = 0xA8B4
Feb 28 12:40:56.455: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x28B4
Feb 28 12:40:56.455: %ISDN-6-CONNECT: Interface Serial0/0/0:19 is now connected to 8042034399 N/A
R1#
Feb 28 12:41:06.223: ISDN Se0/0/1:15 Q931: RX <- CONNECT pd = 8  callref = 0xD272
        Date/Time i = 0x0E021C120B06
                Time (hr:mnt:sec) = 18:11:06
Feb 28 12:41:06.223: %ISDN-6-CONNECT: Interface Serial0/0/1:2 is now connected to 08067186903 N/A
R1#
Feb 28 12:41:06.223: ISDN Se0/0/1:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x5272
Feb 28 12:41:07.219: ISDN Se0/0/1:15 Q931: RX <- NOTIFY pd = 8  callref = 0xD272
        Notification Ind i = 0x80
Feb 28 12:41:08.199: %ISDN-6-DISCONNECT: Interface Serial0/0/1:2  disconnected from 08067186903 , call lasted 1 seconds
Feb 28 12:41:08.199: ISDN Se0/0/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x5272
Feb 28 12:41:08.367: ISDN Se0/0/1:15 Q931: RX <- RELEASE pd = 8  callref = 0xD272
Feb 28 12:41:08.367: ISDN Se0/0/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x5272
Feb 28 12:41:15.935: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 177
Feb 28 12:41:15.935: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x5274 callID = 0xCA60 switch = primary-net5 interface = User
Feb 28 12:41:15.935: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x5274
                Standard = CCITT
        Called Party Number i = 0x80, '00919740979030'
Feb 28 12:41:15.959: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xD274
Feb 28 12:41:17.339: %ISDN-6-DISCONNECT: Interface Serial0/0/1:1  disconnected from 9663422511 , call lasted 105 seconds
Feb 28 12:41:17.339: ISDN Se0/0/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x526A
Feb 28 12:41:17.411: ISDN Se0/0/1:15 Q931: RX <- RELEASE pd = 8  callref = 0xD26A
Feb 28 12:41:17.411: ISDN Se0/0/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x526A
Feb 28 12:41:19.611: ISDN Se0/0/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 49365928
Feb 28 12:41:19.611: ISDN Se0/0/1:15 Q931: Sending SETUP  callref = 0x5275 callID = 0xCA61 switch = primary-net5 interface = User
Feb 28 12:41:19.611: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8  callref = 0x5275
                Standard = CCITT
Feb 28 12:41:19.687: ISDN Se0/0/1:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xD275
Feb 28 12:41:19.691: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xD275
Feb 28 12:41:22.791: ISDN Se0/0/1:15 Q931: RX <- ALERTING pd = 8  callref = 0xD275
Feb 28 12:41:24.791: ISDN Se0/0/1:15 Q931: RX <- CONNECT pd = 8  callref = 0xD275
        Date/Time i = 0x0E021C120B18
                Time (hr:mnt:sec) = 18:11:24
Feb 28 12:41:24.791: %ISDN-6-CONNECT: Interface Serial0/0/1:1 is now connected to 9663422511 N/A
Feb 28 12:41:24.791: ISDN Se0/0/1:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x5275
Feb 28 12:41:24.963: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 918043306189
Feb 28 12:41:24.963: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x5276 callID = 0xCA62 switch = primary-net5 interface = User
Feb 28 12:41:24.963: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x5276
                Standard = CCITT
        Called Party Number i = 0x80, '7848033971'
Feb 28 12:41:24.991: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xD276
Feb 28 12:41:27.691: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 177
Feb 28 12:41:27.691: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x5277 callID = 0xCA63 switch = primary-net5 interface = User
Feb 28 12:41:27.691: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x5277
                Standard = CCITT
Feb 28 12:41:27.715: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xD277
Feb 28 12:41:43.851: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 918043306189
Feb 28 12:41:43.851: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x5278 callID = 0xCA64 switch = primary-net5 interface = User
Feb 28 12:41:43.851: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x5278
                Standard = CCITT
Feb 28 12:41:43.879: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xD278
R1#
Feb 28 12:41:51.155: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0xD230
Feb 28 12:41:51.155: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0  disconnected from 9663011211 , call lasted 1104 seconds
Feb 28 12:41:51.155: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0xCA1C
Feb 28 12:41:51.603: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x5230
Feb 28 12:41:51.623: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xD230
Feb 28 12:41:52.463: ISDN Se0/0/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 354
Feb 28 12:41:52.463: ISDN Se0/0/1:15 Q931: Sending SETUP  callref = 0x5279 callID = 0xCA65 switch = primary-net5 interface = User
Feb 28 12:41:52.463: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8  callref = 0x5279
                Standard = CCITT
        Calling Party Number i = 0x0081, '354'
        Called Party Number i = 0x80, '09581279393'
Feb 28 12:41:52.539: ISDN Se0/0/1:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xD279
Feb 28 12:41:52.539: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xD279
Feb 28 12:41:52.819: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x28B4
Feb 28 12:41:52.819: %ISDN-6-DISCONNECT: Interface Serial0/0/0:19  disconnected from 8042034399 , call lasted 56 seconds
Feb 28 12:41:52.819: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x3D22
Feb 28 12:41:52.843: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0xA8B4
Feb 28 12:41:52.859: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x28B4
Feb 28 12:41:52.995: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 918043306189
Feb 28 12:41:52.995: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x527A callID = 0xCA66 switch = primary-net5 interface = User
Feb 28 12:41:52.995: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x527A
                Standard = CCITT
Feb 28 12:41:53.035: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xD27A
Feb 28 12:41:53.307: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xD27A
Feb 28 12:41:53.715: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0xD27A
        Progress Ind i = 0x8282 - Destination address is non-ISDN
Feb 28 12:41:54.079: ISDN Se0/0/1:15 Q931: RX <- ALERTING pd = 8  callref = 0xD279
Feb 28 12:41:54.151: %ISDN-6-DISCONNECT: Interface Serial0/0/1:1  disconnected from 9663422511 , call lasted 29 seconds
Feb 28 12:41:54.151: ISDN Se0/0/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x5275
Feb 28 12:41:54.219: ISDN Se0/0/1:15 Q931: RX <- RELEASE pd = 8  callref = 0xD275
Feb 28 12:41:54.219: ISDN Se0/0/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x5275
Feb 28 12:41:57.171: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0xD27A
Feb 28 12:41:59.807: ISDN Se0/0/1:15 Q931: RX <- CONNECT pd = 8  callref = 0xD279
        Date/Time i = 0x0E021C120B3B
                Time (hr:mnt:sec) = 18:11:59
Feb 28 12:41:59.807: %ISDN-6-CONNECT: Interface Serial0/0/1:2 is now connected to 09581279393 N/A
Feb 28 12:41:59.807: ISDN Se0/0/1:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x5279
RJ
Silver
This indicate that remote party is rejecting this call obviosly...
Maybe you can change channel order on your isdn side...under "voice port x/x/x:15" you have option for "
isdn bchan-number-order ..."
Can you see if that makes difference?
Also post your "show isdn status" output please...
HTH,
Dragan
HTH, Dragan
Please Sh Isdn status
R1#sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        7 Active Layer 3 Call(s)
        CCB:callid=3D2A, sapi=0, ces=0, B-chan=6, calltype=VOICE
        CCB:callid=3D2F, sapi=0, ces=0, B-chan=1, calltype=VOICE
        CCB:callid=3D30, sapi=0, ces=0, B-chan=5, calltype=VOICE
        CCB:callid=3D31, sapi=0, ces=0, B-chan=4, calltype=VOICE
        CCB:callid=CAEB, sapi=0, ces=0, B-chan=3, calltype=VOICE
        CCB:callid=3D35, sapi=0, ces=0, B-chan=27, calltype=VOICE
        CCB:callid=CAEF, sapi=0, ces=0, B-chan=2, calltype=VOICE
    Active dsl 0 CCBs = 7
    The Free Channel Mask:  0xFBFF7FC0
    Number of L2 Discards = 0, L2 Session ID = 15
ISDN Serial0/0/1:15 interface
        dsl 1, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 1 CCBs = 0
    The Free Channel Mask:  0xFFFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 16
    Total Allocated ISDN CCBs = 7
R1#
Silver
Yes you have famous "MULTIPLE_FRAME_ESTABLISHED" on this one
Great...did you try with changing channel order? Any luck with that?
BTW I would actively speak with provider of PRI ISDN service on this topic...
HTH,
Dragan
HTH, Dragan
Thanks Mate .. right now i am going to change the Channel Order .. Thanks a Ton !!!!!!!
374
