Community Member
External calls to voicemail not working / WMI not working
I hae an AIM-CUE module installed into my 2851 router and when an on network call gets forwarded to voicemain, it works fine.  IE: a call from extension 1001 to 1000 that does not get answered then gets forwarded to voicemail; this works.
However, if a call comes in on the SIP line (off netowrk) the call does get to the correct extension via a translation rule but if that call is now answered it does NOT get to voicemail.
Also, in neither case does the message indicator light become light.  I can manually dial the WMI and via 80001000 and it comes on and 80011000 and it goes off.
Attached are my configs for the route and the CUE.  I also ran a debug ccsip messages and debug ephone state, the results are also attached.
Any ideas why I am having these problems?
2 ACCEPTED SOLUTIONS
VIP Super Bronze
Michael..
The problem seem to be with sip 302 moved temporary message CCME is sending to your provider
Sent:
SIP/2.0 302 Moved Temporarily
Via: SIP/2.0/TCP 185.35.78.39:5070;alias;rport;branch=z9hG4bK653597487
From: "MICHAEL DURHAM" <13525381577>;tag=2119059440
To: <3862439001>;tag=E6A202C-21E9
Date: Fri, 18 Oct 2013 16:16:24 GMT
Call-ID: 472361910@185.35.78.39
CSeq: 25148 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Diversion: <1000>;reason=no-answer;counter=1
Contact: <5000>
Content-Length: 0
Please add this command and test again..Attach the logs again, if it doesnt work
Router(config)#voice service voip
Router(conf-voi-serv)#no supplementary-service sip moved-temporarily
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Michael,
From the logs,
5759 10/23 12:15:24.673 ACCN SIPL 0 UnSolicitedNotificationCallback: Received failed final Response:SIP/2.0 481 Call Leg/Transaction Does Not Exist
Via: SIP/2.0/UDP 10.110.0.2:5060;branch=z9hG4bKJpf9dJnwt2q7L19uNbTyhw~~2
To: <1000>;tag=FE664-1277
Call-ID: 766c5b13-1101@sip:1000@10.110.0.2:5060
CSeq: 1 NOTIFY
Content-Length: 0
Date: Wed, 23 Oct 2013 16:15:24 GMT
We can see that your CUE is attempting to use unsolicited notifcation but its not getting any response back from the ccme because your CCME is not configured correctly..
Please add this config..
sip-ua
mwi-server ipv4:10.110.0.2 transport udp port 5060 unsolicited
ephone-dn xx (xx=your any ephone-dn on your ccme you want mwi for)
mwi sip
or you can use ephone-dn template as suggested by Aman above
ephone-dn-template 1
mwi sip
You need to assign this to your ephone-dns..
Please test again...if it doesnt work please post the following outputs
from CCME
1. debug ccsip messages
from your cue
1.
show software licenses
2. collect the traces as I suggested earlier and send over
Community Member
Can anyone please help me with this issue?  I am still stuck.
VIP Super Bronze
Michael..
Sent:
CSeq: 25148 INVITE
Contact: <5000>
Content-Length: 0
Re: External calls to voicemail not working / WMI not working
I'm unable to pull up the attachments on the mobile tech support app, but check The CUE SIP proxy server (sip server) IP
Address is the sip interface on CME (sip binding on CME/router).
I can check attachments when i get in front of computer later.
Community Member
Thank You
Can you find the below , please?.
voice service voip
allow-connections sip to sip
allow-connections sip to h323
allow-connections h323 to sip
sip
registrar server expires max 1200 min 300
Thank you
please rate all useful information
Michael,
Check these two items out.   The SIP Gateway on CUE needs to match the SIP interface (binding) on CME.
CUE# show ccn subsystem sip
SIP Gateway:                           10.1.2.3
SIP Port Number:                        5060
DTMF Relay:                             sip-notify
MWI Notification:                       outcall
Transfer Mode:                          bye-also
SIP RFC Compliance:                     Pre-RFC3261
CME/ROUTER:
voice service voip
sip
  bind control source-interface Vlan1
bind media source-interface Vlan1
So in above, Vlan1 on the router/CME is IP address 10.1.2.3 which matches the CUE SIP setting.
Community Member
The command, no supplementary-service sip moved-temporarily, fixed the external calls not going to voicemail.  But the WMI light still does not work.  Also,  sometimes when an external call goes to voicemail, the announcementis played and after the beek all you hear is atone.
Thanks for helping me move forward but I still need WMI working.
Did you look at the SIP binding items I posted above?
Community Member
I do not have a VLan option there.
CME_Router(conf-serv-sip)#bind control source-interface ?
  Async               Async interface
  Auto-Template       Auto-Template interface
  BVI                 Bridge-Group Virtual Interface
  CDMA-Ix             CDMA Ix interface
  CTunnel             CTunnel interface
  Dialer              Dialer interface
  GMPLS               MPLS interface
  GigabitEthernet     GigabitEthernet IEEE 802.3z
  LISP                Locator/ID Separation Protocol Virtual Interface
  Lex                 Lex interface
  LongReachEthernet   Long-Reach Ethernet interface
  Loopback            Loopback interface
  MFR                 Multilink Frame Relay bundle interface
  Multilink           Multilink-group interface
  Null                Null interface
  Port-channel        Ethernet Channel of interfaces
  Service-Engine      cisco service engine module
  Tunnel              Tunnel interface
  Vif                 PGM Multicast Host interface
  Virtual-Dot11Radio  Virtual dot11 interface
  Virtual-PPP         Virtual PPP interface
  Virtual-Template    Virtual Template interface
  Virtual-TokenRing   Virtual TokenRing
  vmi                 Virtual Multipoint Interface
On the CUE, do this command:
then paste the output here.
You essentially want to make sure the CUE SIP Gateway IP address matches the SIP interface on the CME/router side.
You can fix this two ways, setting the CME sip binding to match what CUE is using or by changing the SIP gateway setting on CUE but that requires reboot of CUE.
Community Member
CME_Router#service-module service-engine 0/1 session
Trying 10.110.0.1, 2258 ... Open
TDC> show ccn subsystem sip
SIP Gateway:                            10.110.0.1
MWI Notification:                       unsolicited
MWI Envelope Info:                      enabled
Community Member
Here are the results as per your request
Your CUE is currently set to use interface Service-Engine0/1 IP address as it's SIP gateway.
Since you are using SIP with your provider, you need to set the CUE's SIP gateway to be the IP address your provider and CME/router are using for SIP. I can not determine what that is from the CME config, I'm guessing it is one of the GigabitEthernet sub interfaces. Maybe it is GigabitEthernet0/1.110 (10.110.0.1 which the telephony service is using).
On CME/router, you can do this:
Use the 'show sip-ua status' command to see what interface SIP is bound to currently on the router/CME side. The CME and CUE are two independent systems.
voice service voip
sip
  bind control source-interface (SIP interface)
  bind media source-interface (SIP interface)
Or on CUE, change the SIP Gateway address to IP address CME/router is using for SIP (bound interface)
Commands on CUE,
ccn subsystem sip
  gateway address x.x.x.x (IP of interface on CME/router SIP is bound to).
The CUE change above may require reload of CUE. Don't forget to do write mem to save before reload.
** Make sure the interface/IP address you chose to use for SIP is routable throughout your network and CUE can reach it.
** You can't make this change on CME/router side if there are active SIP calls. It may interrupt calls or cause a problem
If you don't do the above, the following on the CME/router may correct the MWI issue.
sip-ua
  mwi-server 10.110.0.1 unsolicited
VIP Super Bronze
Does MWI work for internal calls?
Please send the output of the ff command..
show ccn application
Next I need you to enter the following commands:
no trace all
trace ccn stacksip dbug
clear trace
Now do a MWI test for me using the ff: command, replace xxxx with a valid extension of a user
mwi refresh telephonenumber xxxx
Finally collect the trace and attach it here...Use the command below to collect the logs
show trace buffer long
Community Member
I compared my CUE config with a known working one and added the following information:
ccn subsystem sip
gateway address "10.110.0.1"
mwi envelope-info
dtmf-relay sip-notify
mwi sip unsolicited
transfer-mode semi-attended
end subsystem
MWI does not work at all, internal or external calls,  If you dial 80001000 the MWI light does come on and if you dial 80011000 it goes off.
I can ping my entire network from the CUE prompt but I cannot ping an off-net ip address like 4.2.2.2
'show sip-ua status
SIP User Agent Status
SIP User Agent for UDP : ENABLED
SIP User Agent for TCP : ENABLED
SIP User Agent for TLS over TCP : ENABLED
SIP User Agent bind status(signaling): DISABLED
SIP User Agent bind status(media): DISABLED
SIP early-media for 180 responses with SDP: ENABLED
SIP max-forwards : 70
SIP DNS SRV version: 2 (rfc 2782)
NAT Settings for the SIP-UA
Role in SDP: NONE
Check media source packets: DISABLED
Maximum duration for a telephone-event in NOTIFYs: 2000 ms
SIP support for ISDN SUSPEND/RESUME: ENABLED
Redirection (3xx) message handling: ENABLED
Reason Header will override Response/Request Codes: DISABLED
Out-of-dialog Refer: DISABLED
Presence support is DISABLED
protocol mode is ipv4
SDP application configuration:
Version line (v=) required
Owner line (o=) required
Timespec line (t=) required
Media supported: audio video image
Network types supported: IN
Address types supported: IP4 IP6
Transport types supported: RTP/AVP udptl
Description:                            ciscomwiapplication
Application type:                       aa
Script:                                 setmwi.aef
ID number:                              0
Enabled:                                yes
Maximum number of sessions:             6
CallControlGroupID:                     0
strMWI_OFF_DN:                          8001
strMWI_ON_DN:                           8000
Description:                            msgnotification
Script:                                 msgnotify.aef
ID number:                              1
Enabled:                                yes
DelayBeforeSendDTMF:                    1
logoutUri:                              http://localhost/voicemail/vxmlscripts/mbxLogout.jsp
Description:                            voicemail
Script:                                 voicebrowser.aef
ID number:                              2
Enabled:                                yes
uri:                                    http://localhost/voicemail/vxmlscripts/login.vxml
Description:                            autoattendant
Script:                                 aa.aef
ID number:                              3
Enabled:                                yes
allowExternalTransfers:                 false
busClosedPrompt:                        AABusinessClosed.wav
businessSchedule:                       systemschedule
busOpenPrompt:                          AABusinessOpen.wav
dialByExtnAnytime:                      false
dialByExtnAnytimeInputLength:           4
dialByFirstName:                        false
disconnectAfterMenu:                    false
holidayPrompt:                          AAHolidayPrompt.wav
MaxRetry:                               3
operExtn:                               0
welcomePrompt:                          AAWelcome.wav
Description:                            promptmgmt
Script:                                 promptmgmt.aef
ID number:                              4
Enabled:                                yes
Maximum number of sessions:             1
Press to exit...
5625 10/23 12:15:24.653 ACCN STGN 0 Task: 33000000004GetListMember: output string:unsolicited
5625 10/23 12:15:24.655 ACCN STGN 0 Task: 33000000004GetListMember: Position variable is beyond the string list: number of tokens in the list:1
5625 10/23 12:15:24.658 ACCN SIPL 0 SubscriptionLineImpl: Unsolicited Notify Message being sent:NOTIFY sip:1000@10.110.0.1:5060;transport=udp SIP/2.0
Max-Forwards: 70
To: <1000>
CSeq: 1 NOTIFY
Content-Length: 111
Contact: <1000>
Content-Type: application/simple-message-summary
Event: message-summary
Messages-Waiting: yes
Message-Account: sip:1000@10.110.0.2
Voice-Message: 1/0 (0/0)
Fax-Message: 0/0 (0/0)
CSeq: 1 NOTIFY
Content-Length: 0
5625 10/23 12:15:24.673 ACCN SIPL 0 SubscriptionLineImpl: Unsolicited Notify Message sent, result:false
5625 10/23 12:15:34.674 ACCN SIPL 0 SubscriptionLineImpl: Unsolicited Notify Message sent, result:false
I am confised as to which interface.ip address I should use for following command:
sip
Community Member
Is there anythingelse you need from me?
Do you have a firewall in front of CME doing NAT?
In the SIP debugs above, it looks like IP address 185.35.78.39 is being used for SIP on the outside. Is that nat'd to a intrernal IP address?  I see a interface with ip address dhcp in the provided config, but it is shutdown unless that was a typo.
Do a 'show ip int brief | exc unass' on the CME and see if that 185.x.x.x address is on one of your interfaces or try the MWI server command I mentioned earlier on the CME/router.
sip-ua
Maybe reach out to Cisco TAC or your consulting/partner/etc for further help since the info provided above should get you going on right path.
Community Member
Yes my SIP provider's IP address is 185.35.78.39.  My cell phone is providieng my Interent access and does the NATing.  I used to have HughesNet which is the interface you now see shut down.
I do not have any Cisco support other than these forums.  Here is the result fro the show ip int brief | exc unass command:
Interface                  IP-Address      OK? Method Status                Protocol
Service-Engine0/1          10.110.0.1      YES unset  up                    up
GigabitEthernet0/1.30      192.168.30.1    YES NVRAM  up                    up
GigabitEthernet0/1.69      192.168.69.1    YES NVRAM  up                    up
GigabitEthernet0/1.110     10.110.0.1      YES NVRAM  up                    up
GigabitEthernet0/1.125     192.168.125.1   YES NVRAM  up                    up
GigabitEthernet0/1.200     192.168.200.1   YES NVRAM  up                    up
Loopback1                  192.168.100.101 YES NVRAM  up                    up
NVI0                       192.168.100.101 YES unset  up                    up
I did try the sip-ua command suggested to no avail.  I am so stuck!  I even tried to wipe the CUE-AIM card's config and start from scratch, still not working.
Community Member
Hi Michael,
Below config is wrong in CUE
ccn subsystem sip
mwi sip unsolicited
end subsystem
Below config will work:
ccn subsystem sip
mwi envelope-info
mwi sip unsolicited
end subsystem
Now , since MWI is unsolicited, you MWI ON and OFF numbers are redundant . you can remove those configurations without risk.
10.110.0.2 is your CUE.
so add following commands :
sip-ua
mwi server 10.110.0.2 port 5060 expires 3600 transport udp unsolicited
telephony-service
mwi relay
mwi sip
add this template to all the ephone-dns where you need MWI . These will be button 1 of ephones.
this way MWI will start working.
Still if you have problem with external calls try following
Make voicemail dial-peer exact.
destination-pattern 5000
voice-translation rule 50
rule 1 /.*\(....\)/ /\1/
voice-translation profile CUEVM
translate redirect-called 50
dial-peer voice 5000 voip
description Dial-peer to the Voicemail System"
translation-profile outgoing CUEVM
session protocol sipv2
session target ipv4:10.110.0.2
codec g711ulaw
no vad
Let me know the results.
Aman
“If you have knowledge, let others light their candles in it.”
Ok, on your Cell phone that is doing the NAT...
What  IP on the CME is 185.35.78.39 or 70.209.2.95 NAT'd to?
What I'm trying to figure out is what interface on the CME is the SIP traffc going to from your provider, this way we chose the right interface to bind SIP to so the outside calls don't break.
Does the NAT do SIP inspection of any sort?
What type of cell phone has NAT you can configure?
VIP Super Bronze
Michael,
From the logs,
CSeq: 1 NOTIFY
Content-Length: 0
sip-ua
mwi sip
mwi sip
from CCME
from your cue
1.
Community Member
Community Member
Hi Micheal,
Kindly rate all useful posts.
1593
