Community Member
external calls
Scenario: Two remote sites have VoIP enabled. Both sites can make free calls via WAN. My question is: How does user make external calls? My understanding is the only way out is by using the FXO to connect to the PSTN, is it correct?
Community Member
Re: external calls
you need a connecton to a pstn provider  E1,T1 (Pri) or S0 (bri) or FXO or over IP like SIP.
If you have this connection you need a dial-peer on the voice gateway or route pattern at the cucm (like "dial 9 or 0 for pstn access").
Paul
Community Member
Re: external calls
Thanks Paul,
Much appreciated
Community Member
Re: external calls
So you can make free external calls using SIP?
Community Member
Re: external calls
Legally no ;-)
The SIP connection is only a other leg to your pstn service provider.
In germany we have some pstn service provider, who are offer there service over pri, bri, fxo/s or sip, the charge is similar the same.
Community Member
Re: external calls
I see. Thanks
So VoIP doesnt have much benefits except you can make free internal calls over the WAN link and better managment of the voip phones (no need ro relocate the phones, etc. Correct?
Community Member
Re: external calls
and you don't need extra hardwarecontrollers (i.e e1/t1-vwics) if you use ip-trunks.
290
