External DID not showing
I'm having an issue where all the outbound calls are showing the Main number.  I want to be able to show the DID of the user who called instead of the main number.  I contacted our provider and updated the Pri screening table so all numbers will go out over Caller ID.  They have completed the order.  But I'm still having the same issue.
Under the "Translation Pattern" and "Calling Party Transformations", I have the box checked that says "Use Calling Party's External Phone Number Mask"
What else I could be missing?  Debug shows the calling party number but on the called phone only main number is showing up.
Jan 27 06:29:26.103: ISDN Se0/1/1:23 Q931: TX -> SETUP pd = 8  callref = 0x0119
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98397
                Exclusive, Channel 23
        Display i = 'Test Phone'
        Calling Party Number i = 0x0081, 'XXXXXX8951'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, 'XXXXXX0392'
Jan 27 06:29:26.327: ISDN Se0/1/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8119
Jan 27 06:29:26.927: ISDN Se0/1/1:23 Q931: RX <- ALERTING pd = 8  callref = 0x8119
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Hi Mohammad,
if you are sending out correct calling number to provider but still on the called phone it is not showing correct DID, then it could be issue at provider end.
// Suresh
Please rate all the useful posts
//Suresh Please rate all the useful posts.
I just reached back out to our telco as they told me that they have updated their side and all DID's should be showing up now.
Any place you can suggest I can look if my config is right or do you think my config looks right?
The calling number mask can be applied in Translation Pattern, Route Pattern & Route List, but it seems your config looks good as you sending out the correct DID as calling number.
You can send this debug isdn q931 message to Telco and tell them you are sending out the right number.
Silver
When "deb isdn q931" shows correct called and calling party, then your provider does something wrong, or the format from the calling party is not what they want.
For example, sometimes provider wants to have the last part of the DID range (last 3 or 4 digits)
Some providers want to have the full did number
When using SIP trunks, the providers want to have the full E164 number
discuss with provider
Jan
Just to update everyone on this.  Telco asked me to make the following changes as they need to see that coming from our equipment on the PRI:
Calling Party Numbering Plan: ISDN/E164
Calling Party Numbering Type: National
For some reason some outbound calls started to give me busy signal but it stabalized after like 10 min or so.
Thanks for the update Mohammad. Glad to know the issue is fixed now.
156
