external moh for CUCM
I am looking for a product can support external MOH for our CUCM 8.5.  I am currently running CUCM on VMware so moh-usb-audio is not an option for me.  it seems only option i have is use Fixed Moh Audio Source with moh-usb-audio.  Is there any other options do i have here.  Anybody know or used different solution?  My company have X,Y,Z brand and would like to use some kind of external MOH server and use different MOH for X,Y,Z brands.
Everyone's tags (4)
1 ACCEPTED SOLUTION
Actually since he's looking for external MOH sources he would need to combine the above with the external moh source config:
Configuring Music on Hold from a Live Feed
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemoh.html#wp1010511
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
This would be your option
Appendix B: Integrating Cisco Unified  Communications Manager and Cisco Unified SRST to Use Cisco Unified SRST  as a Multicast MOH Resource
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cusrst/admin/sccp_sip_srst/configuration/guide/srst_appendix_b.html
Integrating Cisco CallManager and Cisco SRST to  Use Cisco SRST As a Multicast MOH Resource
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps5207/products_feature_guide09186a00802d1c31.html
java
java
Hey Java -
Im assuming you can simply add in the moh file in the config for other recordings then for this correct?  And on the device , simply select which file1.wav or file2.wav to play at the router.
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 4
ip source-address x.x.x.x port 2000
max-ephones 240
max-dn 480
system message primary WAN Down - SRST
dialplan-pattern 1 555.... extension-length 4 no-reg
voicemail 5551212
call-forward busy 5551212
call-forward noan 5551212 timeout 12
moh file1.wav
moh  file2.wav
multicast moh 239.1.1.1 port 16384 route x.x.x.x.8 5.5.5.5
date-format dd-mm-yy
java
java
i just read docs you've provided and I have to configure it and see but i think it is going to work.
Thanks everyone for your help.
Hi Vatter, we are looking to do the same thing with Muzak live feed to CUCM 8.5 VM. Just curious, were you able to get this working?
I was really close to configure this but my management drop the ball.  I have to refresh my memory but per Cisco documentation, you can certainly configure this using FXO or T1(E&M) card.  Per people who implemented this suggested to use T1 card option.
4024
