External number shows "Unknown number" on IP phone display
Hi All,
Only 1 of our user getting Unknown number on display for all the incoming external calls. Display is working fine for all Internal calls.
Phone model - Cisco soft phone
Version - 8.6.1.0
CUCM version - UCOS_7.1.5.31900-3.
Attached the screenshot
Waiting for your valuable responses.
Amit
Have you gathered debugs to confirm you're getting the info??
Any TPs or transformation patterns that could be blocking this??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
If you are using FXO line on MGCP gw with CUCM earlier than 8.0 , then there is no work around as it is a bug solved in 8.0
If no, check if you have got caller id display service from your telco or not ?
If not, please describe your netowrk components in more detail
Haitham
Hi Guys,
Thanks for all your reply.
I want to let you know that we have almost 300 users in that location and we have problem only with this user. If there is a problem with the caller ID display from Telco or in the gateway or in TP then the whole users should have affected.
Amit
Re: External number shows "Unknown number" on IP phone display
Hi Guys,
Amit
Hi Amit.
Did you try to change directory number to this phone and see if the problem persist?
Let us know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
Yes I changed the directory number for this phone and it works fine.
Hi Carlo,
Ok.
Check , from cucm route plan report page , if  there is any overlapping DN or route.
Let me know
Carlo
2171
