External Phone Number Mask issue in CUCM 8.6
I'm having an issue with External Phone Number Masks in CUCM 8.6
Until recently our DID ranges were all in the 301-713-nnnn range.  Using the EPNM worked successfully providing CallerID.    We have now added some DIDs with the prefix 301-427.
I have set the Route List Detail Configuration to:
Use Calling Party's External Phone Number Mask*  Off
Calling Party Transform Mask   3014279999
However, when I run debug isdn q931 on the gateway the Calling Party Number = '3017139999'.
It appears that the mask 3014279999 is being changed to 3017139999 by Call Manager,  but I do not know where this is happening.
I do not have any translation  or transformations set.
Have you checked your RP and
Have you checked your RP and the GW?
java
if this helps, please rate
www.cisco.com/go/pdi
The  RP does not  have a
The  RP does not  have a Calling Party Transform Mask set, and the GW does not have a Caller ID DN
VIP Gold
Have you added new E1 for new
Have you added new E1 for new DID numbers in voice router ? and how gateway has added to CUCM, is it H323 ot MGCP ?
Suresh
The DIDs were added to our
The DIDs were added to our existing PRI circuits.  The GW is MGCP
in that particular Route List
in that particular Route List, is there any other Route Group other than 'NESDIS_CO_LD_RG'?
if so, please check the other group configuration too?
//Suresh Please rate all the useful posts.
That is the only RG on the RL
ok, then you may run the DNA
ok, then you may run the DNA & verify the matching translation patterns & route patterns once again. if you couldn't find anything wrong with that, please collect the ccm traces.
VIP Gold
Can you put 301XXXXXXX under
Can you put 301XXXXXXX under Caller ID DN under "Call Routing Information- Outbound calls" of E1 port in CUCM and click apply config and reset it and then test.
Suresh
make sure you had made
make sure you had made changes to the route list that has the same gateway  currently  inn use ... if everything is fine then just reset Route pattern .... it will work fine .....
Dialed Number Analyzer is
Dialed Number Analyzer is your friend.
Thanks all.  I resolved the
Thanks all.  I resolved the issue through further testing.   I had cleared the Caller ID on the Gateway endpoints,  but had not reset the Gateway properly for the change to take effect.
Once I reset the GW with a blank Caller ID, the setting on the Rout List took precedence.
can you explain a bit ... as
can you explain a bit ... as i know on gateway there is option to allow or disable caller id .. we can not manipulate caller id ....
Here is my understanding of
Here is my understanding of the Caller ID.  You can set or change the ID in 4 places:
1.  The DN - set the External Phone Number Mask on the DN on the phone device e.g. if the DN is 1234 and the EPNM is 301713XXXX , the caller ID becomes 3017131234
2. The Route Pattern - you can check the box to use the EPNM set in 1 or leave unchecked and set a mask here in the same way as 1.   A mask set here will overwrite the mask in 1. In my case I want to use the EPNM and I have the option unchecked and no transformation
3. The Route List (Route List Detail) - you can set Use Calling Party's EPNM to ON or OFF or Default.  ON means use the DNs EPNM.  If set to OFF you can set a mask here and this will overwrite the mask in 1. and 2.   I my case I have this set ON to use the DNs EPNM
4. On the Gateway - on the endpoints you can set Caller ID DN in Call Routing Outbound Calls.  This setting overwrites the masks from 1., 2. and 3.   You need to reset the gateway (not just the endpoints) for changes to take effect.   In my case this is blank.  It did have a value of 301713XXXX.  When I removed this I failed to reset the gateway to the setting was still active causing my issue
VIP Gold
Nice summation (+5) !!!
Suresh
Thanks for your explanation..
Thanks for your explanation....yes
1068
