External to IP phones extensions from H.323 calls gateway not working
eug-c
I am trying to configure a H.323 gateway and got external calls working, but not incoming calls to the IP phones. Somehow it is not matching the dialpeers to pass to the CCMs.
I did a debug voip ccapi inout and got this errors as attached.May 23 17:01:38.307: //41/B80C674E8028/CCAPI/cc_api_call_disc_cause_update:
Cause Value=16
I have removed all dialpeers except for 2: dial-peer voice 1003 pots
destination-pattern 9T
progress_ind setup enable 3
progress_ind alert enable 8
translate-outgoing called 3
incoming called-number .
no digit-strip
direct-inward-dial
forward-digits all
dial-peer voice 2123 voip
destination-pattern 2123....
session target ipv4:CCMIPTaddress
All the ISDN connections are up and we can see the calls coming in from debugging q931.
Would surely appreciate any advice you guys can give.
Thanks.
Eugene
paolo bevilacqua
Hi, likely DP 1003 is down configure a port for it. Also, you want codec g711u and no vad under DP 2123.
eug-c
And yes, I was trying to dial to 21236962 and somehow it didn't match any of my dial peers but matched dial peer 1.
Thanks.
Eugene
As I said, seems to me the DP is down for lack of a port configured under it.
