Extracting IP phone serial numbers from Call Manager
I would like to pull a report for the phone serial #s to renew my contract? I am trying to extract this information from SQL database on the Publisher. [CM 4.2(3)]. Is this possible? If yes how?
1 ACCEPTED SOLUTION
Re: Extracting IP phone serial numbers from Call Manager
Hello ,
You can try this little tool , it works greats .
I add a zip file with the little tool and the readme file .
Sorry I didn't find anymore where I have found this on the net . So I can't give you more information about the creator as it is stated in the readme
I hope that it can help you .
Olivier
IP Telephony: How do I find out the serial numbers for deployed phones
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB?cmd=display_location&location=.2cbfc749
you may also try the search feature on NetPro, good chances this has been asked before
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Hello ,
Olivier
Hall of Fame Super Red
Is there a similar app that can be used on CME also?
Blue
hey OKSIAZEK,
open the .asp with what??
the readme states to open the directorylistx.asp and save it as directorylistx.xml but open it with what?
Thanx
Blue
also, attached is the v1.3 version of this tool.
could you be so kind and explain what kind of detail will be exported from the CCM ?
Will it also show the IP of the Phones ?
Steffen
Hi ,
Just open the URL in a web browser and after that simply go to file and save the file to directorylistx.xml
thanks
Olivier
8183
