FAC according to time schedule ...
hi all,
i've got requirement from one of my customer, he wants me to configure Force Authorization Code in such away that,
i) For International calls FAC required all time.
ii) For national calls FAC only after 5pm till 6am.
iii) For managers no need for FAC at all,they must have access on national or international all time without Force Authorization Code.
how we can do it ?????
1 REPLY
Re: FAC according to time schedule ...
I would recommend you to read the TOD section if you need help with the config of this.
1) 1 intl route pattern with FAC enabled
2) 2 route patterns, use TOD for this.
1 will have FAC enabled from 5 pm to 6 am, the other won't
3) create a special set of route patterns without FAC and only managers can reach it
all above is simply combined using CSS and partitions to manage access.
java
if this helps, please rate
java
www.cisco.com/go/pdi
98
