You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
FAC and CMC on CUCM 8.5
                   Hello guys!
I need some advice on the following: a client has authorization codes per user in order to make any type of outbound call doesnt matter if is Intl or Local, etc. Which of the two is best suitable, Forced Authorization codes per users or Client Matter Codes per users? Also, I tested both, both work the same way, but I noticed that there is a big delay after the user enter the code and the actual call connecting to the outside phone, so the users get confused because they think they have to press something more after entering the code. Please some advice and thanks in advanced.
  • IP Telephony
Everyone's tags (4)
2 ACCEPTED SOLUTIONS
Hall of Fame Super Red
Hi Nephtali,
When using codes to allow/disallow calling privileges you want to use FAC's
Here's a clip;
Forced Authorization Codes (FAC) and Client Matter Codes (CMC) allow you to manage call access and accounting. CMC assists with call accounting and billing for billable clients, while Forced Authorization Codes regulate the types of calls that certain users can place.
Client matter codes force the user to enter a code to specify that the call relates to a specific client matter. You can assign client matter codes to customers, students, or other populations for call accounting and billing purposes. The Forced Authorization Codes feature forces the user to enter a valid authorization code before the call completes.
The delay is related to this interaction;
If you do not append the FAC or CMC with #, the system waits for the T302 timer to extend the call. So instruct users to press # at the end of the dial string.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_5_1/ccmfeat/fsfaccmc.html#wp1052254
Cheers!
Rob
"Everything is broken" - Bob Dylan
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
Re: FAC and CMC on CUCM 8.5
You need to hit # (pound/hash) at the end of the code, or wait for the inter-digit timeout to expire (default is 10 seconds)
Hi Nephtali,
Here's a clip;
Cheers!
Rob
Excellent Rob, thanks a lot for the information.
Thanks Brendan for the help.
2018
