FAC/CMC issue Call restriction,Bind code to Phone need
Good day.
Today i've set up FAC for our division.
Route patterns modified.
So now i have to make it works:
Phone A calls LD and INTL only with code 1111
Phone B calls LD and INTL only with code 222 and so on.
The only way i see is create additional CSS and Pt for each the phone and copy existing RPs to this PT.
Is it possible to make it works without creating personal CSS and PTs for each phone?
Thanks.
1 ACCEPTED SOLUTION
No, there's no way to bind a CMC/FAC code to a phone
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
Thanks for your response.
So,it is impossible to make
Is that correct?
Correct, you only enable FAC/CMC in the RPs, anyone that can reach that RP from any phone and has a valid CMC/FAC can make calls.
java
java
Thanks a lot.
225
