FAC codes affecting interdigit timeout
Hey Guys,
I really did not know how else to title the problem. We just implemented FAC on our Cluster for LD and Int calls. When you dial an LD number it prompts you for the FAC. However, once you put it in it takes approximately 20 secs for the call to go thru. If I press # it goes thru right away. I tried using different codes in case one of them was matching a DN or another RL but the problem still persisted. We did it after hrs so it wasnt due to heavy usage. I have never ran into this problem before with other CUCM systems. Im going to wait till tomorrow and hope that it was due to DB replication going on or something along those lines. Didnt get a chance to check the logs or usage with RTMT though.
Jperez
Re: FAC codes affecting interdigit timeout
do you have overlapping on the FACs??
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
As of right now I cant find any overlapping ones. We have a little over 300 though, so im checking again to make sure.
Thanks for the quick reply.
Jperez
Just went over them, and none of them overlap.
Jperez
138
