Community Member
FAC in Inter Cluster Trunk ICT
I am trying to configure the FAC thru Intercluster. Calls are maturing if I remove the FAC from the Route pattern, when I enable FAC calls are not going thru.. I heard that there is a limitation in Inter cluster Trunk (ICT). If yes, can somebody give the URL to refer the same.
DK
1 REPLY
Silver
Re: FAC in Inter Cluster Trunk ICT
There is a known issue CSCee75751 which is documented in the Cisco Bugtoolkit
108
