FAC report from CUCM 6.1.2
Hi All,
I have CUCM 6.1.2 and I need to export around 3000 FACs.I tried to find a native GUI tool to get this report but I could not find such a tool.Is there a third party tool or sql query from CLI on linux to do that?
Any ideas?
Re: FAC report from CUCM 6.1.2
sorry for mis typo, i need to import not export a FAC report from CUCM.
Use BAT
Working with Client Matter Codes and Forced Authorization Codes
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Jav,
As I know BAT is used to upload prepared .txt or .csv file or download it.
My problem is that all 3000 FACs are added before manually. I need now to collect those FACs from CUCM and download them.What is the idea?
BR,
Ahmed
"sorry for mis typo, i need to import not export a FAC report from CUCM."
You said IMPORT, so, that's why I told you to use BAT.
The only option for you is SQL
Not even the import/export has this in 6.1
java
java
hi jav,
thx for your reply.
i got the CLI command which is:
"run sql select name,code,authorizationlevel from facinfo"
BR,
375
