Community Member
FAC UC500
Hi, I configure the UC500 whit the following commands to enable the Force Authorizatin Code:
application
service clid_authen_collect
param uid-len 3
param pin-len 3
aaa new-model
aaa authentication login h323 local
aaa authorization exec h323 local
aaa authorization network h323 local
username 452 password 452
username 452 autocommand exit
dial-peer cor custom
name internal
name local
name international
name international-fac
dial-peer cor list call-international-fac
member international-fac
dial-peer cor list user-international-fac
member internal
member local
dial-peer voice 10 pots
tone ringback alert-no-PI
destination-pattern 9[1-9]T
direct-inward-dial
corlist incoming call-international-fac
corrlist outgoing call-international-fac
ephone-dn 20 dual-line
corlist incoming user-international-fac
dir flash:
enter_account.au
enter_pin.au
But the call is established whitout enter the username and password. The call is established without problem. but the prompt is not heard. What is the error o missing in the configuration?
Source: https://www.myciscocommunity.com/docs/DOC-1400%3Bjsessionid=E5DC5DD8503D5F829C71F08FFF02C2B8
1 REPLY
Hall of Fame Super Gold
Re: FAC UC500
note they use a "loopback" voip DP to trigger the service. You instead only have the pots DP, that is not enough.
All in all is quite complicated, it would be easier to use after-hours and PIN login, or simply a secret prefix that you configure as destination pattern for international calls.
409
