07-02-2008 08:17 AM - edited 03-15-2019 11:42 AM
I want implement FAC with the CUCMBE6.
In the siemens pbx we will replace, the FAC or PIN numbers include an (*) asterisk at the beginning of the number. They want continues using this way. It is possible?, is the * an allowed character in the FAC?.
Thanks.
Solved! Go to Solution.
07-02-2008 08:35 AM
only allowed 0-9, no other thing
javalenc
if this helps, please rate
07-02-2008 08:35 AM
javalenc
07-02-2008 05:49 PM
javalenc , one idea come to my mind, what if i add for example an *96 (the way used in the siemens pbx) to the route pattern:
9.0XXXXXXXXX*96 with FAC enabled.
07-02-2008 07:21 PM
that would require users to dial the whole number + *96 and then when prompted type in the FAC
not sure if this is what you're looking for
javalenc
10-27-2008 09:19 PM
I've hit the same sort of issue with a law firm that uses Auth Codes off of their Option 11 Nortel. Currently they can dial from 3 to 15 digits followed by the "#" key and they can call LD or Int'l.
Has anybody figured out a way to get variable length Auth codes working on Call Manager.
Its a piece of cake to do on the Nortel and Avaya, so I am surprised thus far that Cisco doesn't seem to support wildcards such as in route patterns for the Auth Codes.
If anybody has figured out a work arounf i would love to hear it.
thanks in advance
