Facility IE with H.323
I have the following topology:
Nortel Option 81 --- Qsig --- Cisco 3825 [12.4(3F)] --- Cisco 3825 [IOS 12.4(8c)] --- Qsig --- Avaya
They enabled Q.sig in order to have the Caller Name feature while calling from one PBX to the other. Now the problem is that the caller name is never received.
Taking the debug isdn q931 I see that the caller name is sent in Facility IE.
May 7 18:35:01.344: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x2601
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839E
Exclusive, Channel 30
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0980, '2110'
Plan:Private, Type:Unknown
Called Party Number i = 0x89, '43411'
Sending Complete
Locking Shift to Codeset 5
Codeset 5 IE 0x31 i = 0x80
Codeset 5 IE 0x32 i = 0x81
.May 7 18:35:01.360: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xA601
.May 7 18:35:01.648: ISDN Se0/1/0:15 Q931: TX -> ALERTING pd = 8 callref = 0xA601
Facility i = 0x9FAA068001008201008B0100A1190202B6EA06072B0C0287780101040AC9003414010000000000
Facility i = 0x9FAA068001008201008B0100A1170202B6EB020101800E4352555A2C414C454A414E44524F
Progress Ind i = 0x8188 - In-band info or appropriate now available
.May 7 18:35:01.692: ISDN Se0/1/0:15 Q931: RX <- STATUS pd = 8 callref = 0x2601
Cause i = 0x81E4 - Invalid information element contents
Call State i = 0x04
.May 7 18:35:03.048: ISDN Se0/1/0:15 Q931: TX -> CONNECT pd = 8 callref = 0xA601
Facility i = 0x9FAA068001008201008B0100A1170202B6ED020102800E4352555A2C414C454A414E44524F
Progress Ind i = 0x8182 - Destination address is non-ISDN
Connected Number i = 0xC9, '43411'
.May 7 18:35:03.096: ISDN Se0/1/0:15 Q931: RX <- STATUS pd = 8 callref = 0x2601
Call State i = 0x0A
.May 7 18:35:03.100: ISDN Se0/1/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x2601
I cannot change to MGCP which I know that it supports Facility IE. I'm not sure if newer IOS versions supports Facility or if there is any other workaround that I can use.
Any help will be really appreciated.
Thanks.
Hall of Fame Super Gold
Re: Facility IE with H.323
Hi, my reading of your trace is a bit different.
PBX is not sending caller name (where do see that ?)
Router is sending alerting name and connected name, as received from remote PBX. PBX doesn't like the format (invalid IE), nevertheless the call is established.
Green
635
