Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
factory default 7941,and after that the phone is still upgrading
i made this proccedure to make a factory default to the cisco 7941 ip phone. when i finish the proccedure the guide says that the phone is goint to show "upgrading", and its true, but after that the phone does not do anything, i keep seeing the "upgrading", now... what can i do?
Reset the 7941 and 7961 IP Phones to the Factory Default
Complete these steps:
Unplug the power cable from the phone, and then plug in the cable again.
The phone begins its power up cycle.
Immediately press and hold # while the Headset, Mute, and Speaker buttons flash in sequence. Release # after the Speaker button is no longer lit.
The line buttons flash in sequence in order to indicate that the phone waits for you to enter the key sequence for the reset.
Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash.
If you repeat a key within the sequence, for example, if you press 1223456789*0#, the sequence is still accepted and the phone resets.
If you do not complete this key sequence or do not press any keys, after 60 seconds the Headset, Mute, and Speaker buttons no longer flash, and the phone continues with its normal startup process. The phone does not reset.
If you enter an invalid key sequence, the buttons no longer flash, and the phone continues with its normal startup process. The phone does not reset.
If you enter this key sequence correctly, the phone displays this prompt:
upgrading
thanks
3091
