Factory Reset 7912
HI All,
Can somebody tell me the correct way to factory reset a 7912, that does not require a power cube.
I have found a few different solutions out on the web but a few cause the phone not to come back online.
Nathan
Hall of Fame Super Gold
Re: Factory Reset 7912
If it doesn't back, something is wrong with dhcp/tftp, and you've to check on that.
There are so many posts on the matter if you search.
Sorry i mean the phone dies and you cant do anything with it
Yes that is the situation I answered about and dicussed in countelss postings of the same subject.
Step 1 Press the Menu button.
Step 2 Use the Navigation button to select Settings.
Step 3 Use the Navigation button to select Network Configuration.
Step 4 Perform one of the following procedures:
Procedure A:
- Press **2. The phone displays "Do you want to reset all system settings to default
values?"
- Press the Yes softkey.
Procedure B:
- Press **#. If your phone displays "Enter Admin Password," enter your password and then
press the Enter softkey. Make sure that an unlocked padlock icon appears in the
upper-right corner of your LCD.
- Scroll to Erase Configuration.
- Press the Yes softkey and then press the Save softkey.
The phone cycles through normal startup procedures.
This 100% works and doesnt cause the phone to die.
1906
