factory reset cucm 8
Hi everyone,
lateley i have installed callmanager version 8 based.
I was wondering if its possible to put everyhing in default, so i mean without re-installing cucm again.
Right nowe i have a callmanager with routepatterns configured, also CSS, partitions, h323 gateways, mgcp sip.
I would like to have the whole callmanager empty , so its just like i installed callmanager from scratch.
Is there a quick way to do that? without installing callmanager over again.
This if for lab purposes
  • IP Telephony
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
No, there is no way to erase all configuration without doing it manually. One option for the future would be to take a backup after initial install and keep it should you need to restore back to blank config.
HTH,
Chris
HTH,
Chris
Chris thanks for your reply.
I will keep this in mind for the next time!
169
