Factory Reset Error - UC540
I am trying to factory reset a UC540 (reconfiguring IP to allow use on a network with a DHCP server).
When I run the CCA "Factory Reset" command, I end up with  the following error:
"CUE Reset Failed".
I can't run the setup wizard to configure a different IP address. Either I need to be able to resolve not being able to factory reset or can I set the IP address elsewhere.
1 REPLY
Hall of Fame Super Gold
Re: Factory Reset Error - UC540
Often the CCA is of little use.
Use CLI and you will be able to do or reset whatever you want.
1648
