Community Member
Fail a specific DDI, despite catch-all pattern
I need to intentionally put a specific incoming DDI number "out of service" such that a caller from the PSTN hears a generic message from their carrier/exchange and believes the number is invalid.
Currently my H.323 gateway translates the called CLID to a potentially valid 4 digit extension number. I have a "catch-all" translation-rule which, if no specific match is found, will translate to the switchboard number. This has the affect of catching all calls to currently unassigned numbers.
Can I configure a specific called CLI to fail ? as my catch-all provision is working against me here.
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: Fail a specific DDI, despite catch-all pattern
you can use call reject to achive this...Below is an example of how to ocnfigure call reject
To block a call based on calling number (ANI):
1. Create a voice translation rule and add the numbers you want to block.
BR1(config)#voice translation-rule 1
BR1(cfg-translation-rule)#rule 1 reject /3234441234/
BR1(cfg-translation-rule)#rule 2 reject /3234442345/
BR1(cfg-translation-rule)#rule 3 reject /5155556*/
2. Create a voice translation profile.
BR1(config)#voice translation-profile reject_ANI
BR1(cfg-translation-profile)#translate calling 1
3. Apply the translation profile to your inbound dial-peer.
dial-peer voice 1 pots
Incoming called-number .
direct-inward-dial
port 0/2/0:23
call-block translation-profile incoming reject_ANI
HTH, pls rate useful posts
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
direct-inward-dial
port 0/2/0:23
Community Member
Thanks for this reply.
I am looking to "fail" the call based on the CALLED number, not the CALLING number. ie. ANY external party calling a PARTICULAR DDI terminating on this gateway should get "unreachable". Although I think this may still be possible using the method you describe. Is this still your recommendation ?
I will have a look into this option further and rate as appropriate.
Many Thanks for the quick response
Community Member
Used this example on CALLED number, not CALLING number.
Thanks for your help.
176
