Failed calls over Digital PRI - ISDN with CCM 5.1 with 2801 ISR
I have a couple Cisco ISR 2801 routers running c2801-spservicesk9-mz.124-9.T3.bin IOS.
I am getting the follwing error on my ISDN calls across the (Verizon) PRI:
Cause i = 0x82E3 - Information element not implemented
I have the following configuration on my
Call Manager for the PRI:
Calling Party Presentation: Default
Calling Party Selection: Originator
Called party IE number type: unknown
Calling party IE number type: National
Called Numbering Plan: Unknown
Calling Numbering Plan: ISDN
Any suggestions on what the problem is?
Re: Failed calls over Digital PRI - ISDN with CCM 5.1 with 2801
82 stands for "Identified Channel Does Not Exist". This could be a telco problem with their provisioning. Can you also paste your configs on the controller and serial interface (s0/0:23 or smilar) ?
Controller config is:
controller T1 0/0/1
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
Serial config is:
interface Serial0/0/1:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
Hall of Fame Super Gold
Possibly the switch doesn't like the name IE.
On the router please do "term mon" and "debug isdn q931" to see the complete call progress.
I found the problem. I had the Call Number Plan and Calling Number Plan reversed, and the call was being sent back from the carrier.
Thanks everyone!!
326
