Failed Create CTI Port IVR 7
Hi All,
I have a two cluster, called old and new cluster, i want to migrate IVR 7 from old cluster ( Call Manager 6 ) to new cluster ( call manager 8 ), I was changed the Selected IP AXL Service Providers and CTI Managers on Cisco Unified CM Configuration, Succeed with new IP Call manager, user name, user prifix and password.
When I want to add a new cisco Unified CM Telephony Call Control Group, i got failed message " Failed to created CTI Port and Lines on Cisco Unified CM"
Any help would be much appreciated.
Hi.
Can you check if there are directory number on CUCM overlapping with CTI ports requested range?
Let me know
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Re: Failed Create CTI Port IVR 7
thank you for your response,
Yes sure, There are no conflic or overlapping number, do you have any idea Carlo?
Try to reset the password on Telephony Provider Configuration and also rewrite the same password on application user on CUCM.
Also try to use a simple password.
Carlo
Also verify the JTAPI user credentials.
Yosh
HTH Regards, Yosh
VIP Purple
check for any unassigned DNs in Call manager.
regds,
aman
I was done thats step, i changed user and password and reset CCX Engine, but still failed when add a new cisco Unified CM Telephony Call Control Group.
do you have any suggestion Carlo?
Best Regards,
Gilang
Hi Gilang.
I can suggest you to install RTMT plugin (available on UCCX) and give a look to UCCX Logs.
If you can, please upload here so that we can analyze them
Let me know
Carlo
OOPPSS...
I read better your first post.
Unfortunately IVR 7 is not compatible with CUCM 8
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/crs/express_compatibility/matrix/crscomtx.pdf
Sorry
Carlo
Carlo Thanks a lot for your attention and your kindness
150
