Failed Faxes
Mojo1
We have a legacy PBX which our analog fax lines are located. All calls made from a fax machine or received enter and exit through our Cisco 2821 Router. We are getting alot of failed outgoing faxes. Can someone suggest something we need to do, possibly reprogramming the router??
Thank You
11 Replies 11
paolo bevilacqua
Begin checking "show controllers T1" for slip errors.
What does a slip error indicate?
A frame alignment mismatch causing fax and modem to fail.
Do you have these errors ?
I will check
in the command prompt is says NMMI2821#
what is the command I should type?
As mentioned above, "show controllers T1".
NMMI2821#show controllers T1
T1 1/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
Description: ***Qwest 54.HGCS/5.-972577***
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20071011, FPGA: 255, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
Current port master clock:recovered from backplane
Data in current interval (538 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
T1 1/1 is up.
Description: ***Long Distance T1/////54.HCGS/5.974516***
No alarms detected.
Framing is ESF, Line Code is AMI, Clock Source is Line.
Data in current interval (565 seconds elapsed):
40 Line Code Violations, 23 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 5 Line Err Secs, 1 Degraded Mins
5 Errored Secs, 3 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
46790 Line Code Violations, 20463 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 3005 Line Err Secs, 286 Degraded Mins,
3011 Errored Secs, 2379 Bursty Err Secs, 1 Severely Err Secs, 0 Unavail Sec
s
T1 1/0/0 is up.
Description: ***T1 Tie to Avaya***
No alarms detected.
Version info Firmware: 20071129, FPGA: 20, spm_count = 0
Data in current interval (594 seconds elapsed):
12 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
12 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
1975 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
1975 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
T1 1/0 is up.
No alarms detected.
T1 1/1 is up.
No alarms detected.
s
T1 1/0/0 is up.
No alarms detected.
Configure:
network clock/participate wic 1
network-clock-select 1 t1 1/1
controller t1 1/0/0
clock source internal
And check for slips stopping or increasing.
I tried these settings. The first 2 were already in there.
When I adjusted the clock source to internal for the long distance t1, the errors increased. I have moved it back to a clock source of line. The errors have slowed down, but are still slipping.
Not sure if you configured the right controller or not.
I meant, change clock source internal under controller going to PBX, not long distance.
