Community Member
Failed outgoing fax over satellite
I am having problems sending a fax over a satellite link. I can receive faxes over the satellite but I can?t send a fax over the satellite. Below are my configs:
Remote location
voice-port 0/1/3
input gain 10
output attenuation -6
echo-cancel coverage 32
timeouts interdigit 3
connection plar 323
description PSTN
dial-peer voice 212 pots
destination-pattern 212
port 0/1/3
dial-peer voice 323 voip
destination-pattern 323
session target ras
dtmf-relay h245-signal
codec g711ulaw
fax-relay ecm disable
fax rate 9600
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
dial-peer voice 324 voip
description BACKUP ROUTER
preference 1
session target ipv4:1.1.1.17
codec g711ulaw
fax rate 9600
Fax Location
voice-port 2/0/0
connection plar 212
description FAX Machine
dial-peer voice 3125 pots
port 2/0/0
dial-peer voice 2004 voip
preference 4
session target ras
codec g711ulaw
fax rate 9600
dial-peer voice 2005 voip
preference 5
session target ipv4:1.1.1.23
codec g711ulaw
fax rate 9600
I am not able to send a fax from the Fax location to the Remote location.
1 REPLY
Re: Failed outgoing fax over satellite
I would not expect it to work over a satellite link, I'm guessing the delay is too great for t.38.
Do you have it working anywhere else over satellite?
221
