failed to Connect softphon to SIP Gateway
Hi Guys,
Kindly I configured my Cisco Router 3700 as CallManager, using SIP protocol, but we trying to connect from SoftPhone (using ZOIPER) i get error no route to destination my configuration is
R1#show  version
Cisco IOS Software, 3700 Software (C3725-ADVENTERPRISEK9_IVS-M), Version 12.4(15)T9, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 28-Apr-09 16:14 by prod_rel_team
ROM: ROMMON Emulation Microcode
ROM: 3700 Software (C3725-ADVENTERPRISEK9_IVS-M), Version 12.4(15)T9, RELEASE SOFTWARE (fc5)
Basra uptime is 3 hours, 1 minute
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19
System image file is "tftp://255.255.255.255/unknown"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3725 (R7000) processor (revision 0.1) with 249856K/12288K bytes of memory.
Processor board ID FTX0945W0MY
R7000 CPU at 240MHz, Implementation 39, Rev 2.1, 256KB L2, 512KB L3 Cache
3 FastEthernet interfaces
3 Serial(sync/async) interfaces
DRAM configuration is 64 bits wide with parity enabled.
55K bytes of NVRAM.
16384K bytes of ATA System CompactFlash (Read/Write)
Configuration register is 0x2142
R1#show running-config
Building configuration...
Current configuration : 1855 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
voice service voip
allow-connections sip to sip
sip
registrar server expires max 1200 min 300
voice register global
mode cme
source-address 192.168.3.1 port 5060
max-dn 5
max-pool 5
create profile sync 0001010036138206
voice register dn  1
number 1000
call-forward b2bua busy 100
call-forward b2bua noan 100 timeout 20
allow watch
name TEST
label 123456789
voice register pool  1
id mac 000C.2932.B096
number 1 dn 1
dtmf-relay sip-notify
username test password test
codec g711ulaw
archive
log config
hidekeys
interface FastEthernet0/1
ip address 192.168.3.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/0
duplex auto
speed auto
Log ZOIPER SoftPhone is
23:49:42 Registering user 'test@192.168.3.1:5060'
23:49:43 Failed registration  for 'test@192.168.3.1:5060' with cause 'no route to destination'
23:49:44 Registering user 'test@192.168.3.1:5060'
23:49:45 Failed registration  for 'test@192.168.3.1:5060' with cause 'no route to destination'
23:49:49 Failed registration  for 'test@192.168.3.1:5060' with cause 'no route to destination'
23:49:53 Failed registration  for 'test@192.168.3.1:5060' with cause 'no route to destination'
23:49:54 Unregistering user 'test@192.168.3.1:5060'
Pleas can anyone till me whats gone on ? thanks for support. :thankyou:
1 ACCEPTED SOLUTION
Re: failed to Connect softphon to SIP Gateway
Hi Sabah
On Zoiper as username and display name use 1000 and username test as authorization name
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi Sabah
Carlo
Hi Carlo,
very thanks about reply, now the connection done successfully .
1491
