Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Failed to generate CDR / CAR
I have a little problem with the CDR, today i want to CDR since 1/feb/2012 to 28/feb/2012 however the server displays the following msg:
30024: Data is available only from Feb 21 2012, do u want to generate the report?
I already have realised these steps:
  • System> Service Parameters> Cisco CallManager      service
    • CDR Enabled Flag
    • CDR Log Calls with zero duration flag
    • Call Diagnostics Enabled
  • System-->Enterprise Parameters-->CDR Parameters
    • CDR File Time Interval: 1
    • Cluster ID: StandAloneCluster
  • Tools -> Feature Services
    • Cisco SOAP - CDRonDemand Service (This should be       running on the First Node only)
    • Cisco CAR Web Service (Again, First Node only)
  • Tools -> Network services
    • Cisco CDR Repository Manager (this one should be       running on the First Node only)
    • Cisco CDR Agent (these should be running on all the       call processing nodes)
    • Cisco CAR Scheduler (this should be running on the       First Node only)
  • If all the above services are running okay, then, as a      first step, can you please try this:-
    • Disable the "CDR Enabled Flag" parameter in       all the servers in your cluster.
    • Restart the "Cisco CDR Agent" service in all       the servers in your cluster.
    • Restart the "Cisco CDR Repository Manager"       service in the publisher server.
    • Restart the "Cisco Database Layer Monitor"       service in all the servers in your cluster.
    • Enable again the "CDR Enabled Flag"       parameter in all the servers in your cluster.
however the problem still present... some idea???????????
Thanks in advanced,
310
