Failed to magrating 7940 ip phones between 2 clusters remotely
Just failed to magrating 7940 ip phones between 2 cluster yesterday
Some information of 2 clusters
Cluster A has just been upgraded from 6.1.2 to 8.6.2-21900 , and Cluster B upgraded from 8.5.1 to 8.6.2- 21900.
Cluster A used for the Shanghai Office , Cluster B used for others cities
We planned to magrate about 40 7940 iphones and 100 6921 iphones registered in Cluster A to Cluster B  but finally failed.
following is what we had done .
1  changed "PREPARE CLUSTER FOR ROLLBACK TO PRE 8.0 “ from false to true  in CUCM A
2  restarted TVS and TFTP service
3  reset those  iphones
4   change the DHCP settings on the remote SWITCH
as the result ,  all 6921  IP phones  successfully magrated between 2 clusters but 7940 failed
Is there any mistakes we made  or some other points we should take attention??
Everyone's tags (5)
Try delete CTL/ITL files manually in 7940 ip phones!
hi pqcristovam
  i have not  fund CTL/ITL files in 7940 ip phones..
  i had just test for magrating 7940 ip phone  between 2 clusters in the lab of Shanghai office successfully, but failed in the remote office with the same way.
Blue
You can find video in below post for deleting CTL file
https://supportforums.cisco.com/message/3313999#3313999.
If you do not have CTl file. You can reset your ip phone to factory default and register to new CUCM cluster.
Ronak Patel
rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
1262
