06-01-2012 07:00 AM - last edited on 03-25-2019 08:15 PM by ciscomoderator
Unity connection worked fine but for some odd reason UCM isn't working. It fails after about 1 hour or so.
Attached is the log file. Thanks,
J
06-01-2012 01:47 PM
HI,
How much RAM memory you have on the server? For 8.5 versions, 4 GB is strongly recommended.
From the log file I see this:
E5606 @ 2.13GHz, 3072 MB Memory:
Tere.
If you find this post helpful, please rate!
06-01-2012 07:18 PM
Strongly recommended but not a min requirement. We do have 3GB but I doubt this is the issue. I will upgrade to 4 on monday and try again.
Thx
Julien
sent from my BlackBerry----
06-01-2012 07:21 PM
You might want to try a new media.
Please rate useful posts
06-01-2012 07:31 PM
This media was given to me by cisco. They are looking through the upgrade logs also. Just hopping somebody had this issue also
Julien
06-01-2012 07:37 PM
I have had a media sent directly from cisco, it wont even pass media check test let alone install..I have had a media passed media test and failed after 1hr of install. It may not be a media issue but if you have a different one you may want to try it
06-02-2012 09:05 AM
if possible can you go to RTMT and get the install log, not the date log that you have attached, there should be a file install.log, also can you provide the following.
also from the ssh can you get me
file get inactivelog /cm/trace/dbl/sdi/installdb_l2*file get activelog /cm/trace/dbl/sdi/installdb_l2*
06-04-2012 08:34 AM
06-04-2012 10:51 AM
06-05-2012 12:57 AM
Sorry for the late reply Julien.
This is what i see in the logs
Name of the file
It should only be UCSInstall_UCOS_8.5.1.13041-1.sgn.iso, kindly rename the file, this is causing dependencies errors when extracting and installing rpm files
Snippet below
06/04/2012 03:21:39 install_rpm.sh|netdump-server rpm failed to install: trying nodeps(rc=1)|<:INFO>
06/04/2012 03:21:39 install_rpm.sh|Installing netdump-server-0.7.16-15.i386.rpm with --nodeps|<:DEBUG>
06/04/2012 03:21:39 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/8.5.1.13041-1/RPMS/netdump-server-0.7.16-15.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
06/04/2012 03:21:39 install_rpm.sh|(CAPTURE) error: Failed dependencies:|<:DEBUG>
06/04/2012 03:21:39 install_rpm.sh|(CAPTURE) /usr/sbin/sshd is needed by netdump-server-0.7.16-15.i386|<:DEBUG>
06/04/2012 03:21:39 install_rpm.sh|[212/213]: dhcp-3.0.1-68.el4.i386.rpm|<:DEBUG>
06/04/2012 03:21:39 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/8.5.1.13041-1/RPMS/dhcp-3.0.1-68.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
06/04/2012 03:21:39 install_rpm.sh|[213/213]: sysstat-5.0.5-25.el4.i386.rpm|<:DEBUG>
06/04/2012 03:21:40 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/8.5.1.13041-1/RPMS/sysstat-5.0.5-25.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
06/04/2012 03:21:40 install_os|Generating /etc/modprobe.conf|<:INFO>
Can you rename the file to the format i have given and retry the install.
i.e
UCSInstall_UCOS_8.5.1.XXXXX-Y.sgn.iso
MD5 checksum : e9fac7144f4060014136b01af62067b6
hope this helps
06-05-2012 05:32 AM
Thanks for the tip, Unfortunately, this is a Media CD given to me by Cisco because our PUT wasn’t working. I will ask them to produce another CD with what you suggested.
Julien Franche
Systems Administrator / Ottawa
Tél./Tel. 613-786-0124
gowlings.com <>>
06-05-2012 01:26 PM
Changing the name for the install didn't work and I confirmed that the MD5 checksum matched.
Attached are the install logs and alos the CLI active and inactive install db logs.
thanks,
Julien
