Failover\fallback on SIP trunk
Hi!
Really a noob when it comes to SIP trunks and I am not sure how to set up fallback from one SIP trunk to another? I am running CUCM 8.0.3 and we are running SIP trunks between 2 Trio servers. In the SIP trunk config I only have the possibility to add one IP adresse and I can't add a sIP trunk in "route Group" like I have done with the E1 on the Gateways.
So.....anyone out there that can point me in the right direction?
Eirik
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Eirik,
You can certainly add SIP trunk to a route group, but you fist need to remove it from any route patterns that reference it directly.
HTH,
Chris
Eirik,
HTH,
Chris
You are so correct Thank you so much!
343
