Failover Firstnode to Subsequent node Timer setting
I have a cluster with a Firstnode and a Subsequentnode. The sw version is 6.1 When I test the failover ( disconnect the UTP cable ) the phones switches over to the Subsequentnode and that works fine. But it took about 20 seconds for the failover. Is it possible to change the timer ?
1 ACCEPTED SOLUTION
Green
Re: Failover Firstnode to Subsequent node Timer setting
Nop...
I would say that is expected, since TCP sessions are timing out and thats part of TCP protocol.
If You stop CCM service failover should happen inmediatly since we are sending TCP RST
1 REPLY
Green
Nop...
90
