Failover question
If IP phones are failed over to a backup server and the primary comes back online, will calls in progress be impacted as the phones switch back over to the primary?
Also, will the phones need to reboot, or will they just silently re-home to the primary?
And finally, is re-activating a primary server something that can be done during normal business hours usually?
TIA.
Green
Re: Failover question
No, the algorithm for the fallback will be executed after active calls are finished.
They just silently re-home, no need to do a manual reboot.
Is re-activating a primary server something that can be done during normal business hours usually.
This will depend on many factors, (Number of IP Phones, if remote locations involved WAN bandwitdh, etc) I would recommend it do it after hours in order to avoid high CPU, lack of resources, bottlenecks...etc.
Bronze
Well... Cisco stated that active calls will not disconnect during failover.
I am not sure true or not.
Last time I upgrade from 4.13sr2 to 4.13sr3c with OS upgrade, I got disconnect during rehome back to publisher:
1. Stay connect during upgrade publisher, reboot publisher. I make sure publisher become standby at IP phone screen.
2. got disconnect during upgrade subsrciber for some reason. I saw the phone reboot, but comes up so fast.
Ken
hi Jolo,
there will be reboot if call is not in progress but if its in progress ip phone wil nt take a reboot till the you wont hung up..
Bronze
I totally understand what you guys try to say here.
However, in my real experience, it will reboot my phone during upgrade even I am on the phone. Actually it happened couple times during the upgrade... it just weird.
Ken
yeah in that case something is realy wrong...
Green
Do you remember the phone load and phone model?
145
