Failure to register a MGCP gateway
Yesterday we lost the connection to a gateway for a few hours, returning the connection the gateway was not recorded in the CUCM, after making a show ccm-manager is always in registering:
MGCP Domain Name: ILL05254
Priority Status Host
Primary Backup Ready 10.127.32.155
First Backup Registering with CM 10.127.32.28
Second Backup None
We have deleted the configuration of the CUCM GW and the endpoint and created again and swings between registered and unregistered continuously.
The ISDN are correct:
# Sh isdn status ILL05254
Global ISDN primary-4ESS switchtype =
% Q.931 is to CCM MANAGER 0x0003 backhauled on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0: 15 interface
         dsl 0, interface ISDN primary-QSIG switchtype =
          Slave side configuration **** ****
         L2 Protocol = Q.921 0x0000 L3 Protocol (s) = CCM MANAGER 0x0003
     Layer 1 Status:
         ACTIVE
     Layer 2 Status:
         TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
     Layer 3 Status:
         0 Active Layer 3 Call (s)
     Active dsl 0 CCBs = 0
     The Free Channel Mask: 0xFFFF7FFF
     Number of L2 Discards = 0, L2 Session ID = 1
     Total Allocated ISDN CCBs = 0Deshacer cambios
Internal calls are working correctly but not receive calls to DDI as the Gateway does not work.
Any idea???
Thanks!
here are a few things to check:
- make sure domain name for mgcp router is the same on both router and cucm config page (case sensitive)
- do "no mgcp" , "mgcp" to restart/download config
- remove "mgcp bind ...." and re-enter if you have bind cmd
thanks Tun Moe,
I did it so many times, and tried to register MGCP Gw to other CUCM in the cluster but stills fails, seems a firewall issue or something else....
Regards.
VIP Super Bronze
Ivan,
Is your mgcp gateway hostname still the same as whats configured on cucm. Like Tun said check that you dont have the command ip domain-name configured and if you do then this must be configured as your router hostname.domain-name in cucm config...
can you send a debug mgcp packets here
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi all,
Yes is the same name in Gw than in CUCM, seems a firewall problem because we have now more Gw with the same problem. in Gw shows always in registering and in CUCM is flopping between registered and unregistered.
Firewall and Security team are reviewing problem, may be a firewall issue, when we had the configuration I will say you.
Thanks and regards!
Green
For MGCP make they are allowing these ports
Gateway
Unified CM
2427 / UDP
Media Gateway Control Protocol (MGCP) gateway control
Gateway
Unified CM
2428 / TCP
Media Gateway Control Protocol (MGCP) backhaul
Alex
Regards, Alex. Please rate useful posts.
Hi all
Finally the problem has been resolved by firewall team
About the resolution they said that a rule in the firewall that were put to inspect SIP packets made gateways go to unregistered. Although that rule is for port 5060 in SIP and GWs goes in 2427 and 2428 in MGCP, this was the cause of the problem, and after eliminating that rule were registered with no problem.
I don´t know it this solution provided by firewall team is real of fake because they made something wrong and they gave us that solution, by the way all is working fine....
Thanks all and regards!
In my (limited) experience, SIP inspection on firewalls doesn't work...
GTG
Please rate all helpful posts.
1354
