Community Member
Fast busy sending call to H.323 GW
CM 4.2(3) connected to 3825 with MultiFLex T1 card connected to Avaya PBX. Originally, the router was an H.323 GW and the T1 was a DS0/CAS circuit. I was able to offnet calls fine. Then to set up for E911, we changed the T1 to a PRI. Avaya operator changed his end, I changed the router config. Sh voice port summary and sh controller indicates all is good. I went to the CM and the GW. Now, calls going to the GW get fast busy.
Config below as well as show commands. I trimmed the show run:
isdn switch-type primary-ni
voice-card 0
dspfarm
dsp services dspfarm
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24
controller T1 0/0/1
framing esf
linecode b8zs
interface GigabitEthernet0/0
description Link to 008
duplex auto
speed auto
media-type rj45
negotiation auto
h323-gateway voip interface
h323-gateway voip h323-id 3825-1
h323-gateway voip tech-prefix 1#
h323-gateway voip bind srcaddr xxx.xxx.xxx.xxx
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
negotiation auto
interface Serial0/0/0:23
no ip address
isdn incoming-voice voice
no cdp enable
control-plane
voice-port 0/0/0:23
echo-cancel enable type hardware
!dial-peer voice 1 pots
description Dial Peer for Outbound 4 digit on post dialing
destination-pattern ....
forward-digits all
On the CM, the GW window shows the GW, known by its IP address, device protocol H.225, and registration unknown
Re: Fast busy sending call to H.323 GW
On the router, do a SH ISDN status. If it has correct layer 1 operation, it should be in Multi Frame Established.
Next, enable 'debug isdn q921' and do a shut/no shut on the T1 controller. Capture these logs, then turn off these debugs.
Finally, enable 'debug isdn q931' and make a test call through the gateway and capture these logs. Post them here so we can go through them.
Community Member
OK, looks like I have a Layer 2 issue. Sho ISDN status indicates that the state is alternating between TEI_Assigned/Awaiting_Establishment
Show ISDN Status below:
3825-1#sh isdn status
Global ISDN Switchtype = primary-ni
ISDN Serial0/0/0:23 interface
dsl 0, interface ISDN Switchtype = primary-ni
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 176
Total Allocated ISDN CCBs = 0
Hall of Fame Super Gold
router needs to be ISDN network-side:
int Serial0/0/0:23
isdn protocol-emulate network
Community Member
OK, last post from p.bevilacqua fixed my L1/L2 problem - I now have MultiFrame Established. I have run the debugs as requested by a previous poster. Debug isdn q921 is below. Debug q931 and then placing a call produced not debug output
3825-1#debug isdn q921
debug isdn q921 is ON.
*Jan 23 16:40:09.987: ISDN Se0/0/0:23 Q921: Net RX <- RRp sapi=0 tei=0 nr=48
*Jan 23 16:40:09.991: ISDN Se0/0/0:23 Q921: Net TX -> RRf sapi=0 tei=0 nr=48conc t ft t
*Jan 23 16:40:20.055: ISDN Se0/0/0:23 Q921: Net RX <- RRp sapi=0 tei=0 nr=48
*Jan 23 16:40:20.055: ISDN Se0/0/0:23 Q921: Net TX -> RRf sapi=0 tei=0 nr=48f t
*Jan 23 16:40:30.119: ISDN Se0/0/0:23 Q921: Net RX <- RRp sapi=0 tei=0 nr=48
*Jan 23 16:40:30.119: ISDN Se0/0/0:23 Q921: Net TX -> RRf sapi=0 tei=0 nr=48
3825-1(config-controller)#shut
*Jan 23 16:40:38.243: %CONTROLLER-5-UPDOWN: Controller T1 0/0/0, changed state to administratively down
*Jan 23 16:40:38.247: %ISDN-6-LAYER2DOWN: Layer 2 for Interface Se0/0/0:23, TEI 0 changed to down
*Jan 23 16:40:40.243: %LINK-3-UPDOWN: Interface Serial0/0/0:23, changed state to down
3825-1(config-controller)#no shut
3825-1(config-controller)#exit
3825-1(config)#exit
3825-1#
*Jan 23 16:41:06.719: %SYS-5-CONFIG_I: Configured from console by girardj on console
*Jan 23 16:41:09.955: %CONTROLLER-5-UPDOWN: Controller T1 0/0/0, changed state to up
*Jan 23 16:41:09.955: ISDN Se0/0/0:23 Q921: L2_EstablishDataLink: sending SABME
*Jan 23 16:41:09.955: ISDN Se0/0/0:23 Q921: Net TX -> SABMEp sapi=0 tei=0
*Jan 23 16:41:10.955: ISDN Se0/0/0:23 Q921: Net TX -> SABMEp sapi=0 tei=0
*Jan 23 16:41:10.959: ISDN Se0/0/0:23 Q921: Net RX <- UAf sapi=0 tei=0
*Jan 23 16:41:10.959: %ISDN-6-LAYER2UP: Layer 2 for Interface Se0/0/0:23, TEI 0 changed to up
*Jan 23 16:41:11.955: %LINK-3-UPDOWN: Interface Serial0/0/0:23, changed state to up
*Jan 23 16:41:21.067: ISDN Se0/0/0:23 Q921: Net RX <- RRp sapi=0 tei=0 nr=0
*Jan 23 16:41:21.067: ISDN Se0/0/0:23 Q921: Net TX -> RRf sapi=0 tei=0 nr=0
*Jan 23 16:41:31.131: ISDN Se0/0/0:23 Q921: Net RX <- RRp sapi=0 tei=0 nr=0
*Jan 23 16:41:31.131: ISDN Se0/0/0:23 Q921: Net TX -> RRf sapi=0 tei=0 nr=0
3825-1#no debug all
Port Statistics for unclassified packets is not turned on.
236
