fast busy tone after transferring externals calls
Criss Sawyer
i use CCM 7.0 and H323 gateway cisco 2811. internal call forwarding works fine.
From my ip phone, i call my cell phone then i try to transfer the call to another cell phone so the 2 cell phones can reach each other, after pushing transfer softkey botton i heard a fast busy tone in my cell phone.
the attach file contain the sh run of my Gateway
any ideas
thx in advance
Rob Huffman
Hi Bilal,
Try this Service Parameter under CUCM "Block External-to-External Transfer"
make sure it is set to "False".
Cheers!
Rob
hi rob,
thank you for your response.
Did you mean Block OffNet To OffNet Transfer ?
if yes, this service is already set to "false"
In my environement, i have CCM 7.0 and 2 gatways h323 3825 and 2811 (all within same Vlan). the 2 gateways are configured the same way but the call transfer works fine with the 3825 gateway but it does not with the 2811 one.
