fast busy tone after transferring externals calls
i use CCM 7.0 and H323 gateway cisco 2811. internal call forwarding works fine.
From my ip phone, i call my cell phone then i try to transfer the call to another cell phone so the 2 cell phones can reach each other, after pushing transfer softkey botton i heard a fast busy tone in my cell phone.
the attach file contain the sh run of my Gateway
any ideas
thx in advance
Hall of Fame Super Red
Re: fast busy tone after transferring externals calls
Hi Bilal,
Try this Service Parameter under CUCM "Block External-to-External Transfer"
make sure it is set to "False".
Cheers!
Rob
hi rob,
thank you for your response.
Did you mean Block OffNet To OffNet Transfer ?
if yes, this service is already set to "false"
In my environement, i have CCM 7.0 and 2 gatways h323 3825 and 2811 (all within same Vlan). the 2 gateways are configured the same way but the call transfer works fine with the 3825 gateway but it does not with the 2811 one.
261
