Fastbusy during transfer one IP phone to another
Hi, gent's.
Scheme:
I have local CUCM 7.1.5 at location A + far site CUCM 7.1.5 at location B. They are connected via Non-GK-Controled Intercluster Trunk.
Media Termination Point Required option are ckeck out at both site.
Phone 2222 is  registered at location A. Phone 2444 is registered at location B.
Problem:
Time to mime I've got a fast busy tone then i tryed TRANSFER call from  ext 2222 to ext 2444. Sometimes call is established and sometimes only fastbusy.
Any ideas ?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Why do you have MTP checked?  Any spcific reason for it?
Are all CUCM servers included in the ICTs?
Chris
Chris
Hello, Chris.
Sorry for confusion ) and bad explanation.
I mean that The Media Termination Point DOES NOT SELECTED (not checked)
How many servers are in each cluster?
Chris
Hi, Chris.
Sorry for delay.
2 nodes at leach site. I suppose the problem at tanscoder. now checking that issus. I have no more ideas )
You should not need transcoders between cisco phones even if they are on seperate clusters as the phones can negotiate the codec to agree on.  The only plan of action I see is to review the CM SDI traces to see what causes the drop.
HTH,
Chris
Chris.
Actually I do not understand how phones can negotiate the codec by themself. Do they have buil-in transcoder ?
According trace: What options do I need to check in ? I supose something like that
May be you will advice a programfor  trace overview in advance ?
Yes, phones have built in DSPs that allow it to speak various codecs, so when a call is negotiated as part of the setup message phones agree on codec and they use it natively without the need for external xcoder.
You need Detailed tracing with H245 traces on.
Chris
Hello, Chris.
It seem to me that trascodrer is needed
Codec negotiation. I suppose i should disable g722 code.
355
