Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
FastDial in a service
Hi guys
I am writing to you about the service I have worked in the past and stopped working without explanation.
I have phone service set the path to the directory PC.
When you click on the service you have presented them I set shortcuts in ccmuser.
Malfunction : When I click on the service fastdial I get authentication error.
When I copy the path exists in the web line phone service I get the xml. Announcement it should display "authentication error" as I get on the phone. Malfunction. When I click on the service fastdial I get authentication error.
When I copy the path exists in the web line phone service I get the xml. Announcement on the xml should display "authentication error" as I get on the phone.
I test it Several times without success Does anyone have insight ?
cucm ver 8.6
phone tested 79xx
Thanks sharon.
1 REPLY
Re:FastDial in a service
I Fix it .it works fine
Sent from Cisco Technical Support Android App
319
