Community Member
Fastdials and Personal Address Book
Upgraded from CCM 3.3 to CCM 6.1. After the upgrade, users are unable to access Fastdials and Address Book from their phone. They receive an HTTP 404 error on the phone itself. I have updated the subscriptions with the current PIN. Ideas?
Re: Fastdials and Personal Address Book
both services are now embedded under the directories button of the phones. there is no need for a separate service
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
So if they are now embedded, where can I put the username and password inline so the user doesn't have to login?
refer to this bug, use the bug toolkit to see all details
CSCso28287
Restore Fast Dials usage as a service on Linux, better than on Windows
Symptom:
Fast Dial usage not the same on 5.x/6.x as it was previously on 3.x/4.x / Windows
Conditions:
Attempting to use Fast Dials on 5.x, 6.x as they were available in Windows
Workaround:
None
java
java
Community Member
So basically functionality has changed and you cannot make it function as before is what I am reading in this bug.
have you looked at the bug using the bug toolkit as i mentioned??
java
java
Community Member
I have tried this procedure on a CUCM 7.0.1.11000-2, and cannot get the authentication to work. Anybody else have any luck with this bugfix?
Community Member
sorry, capitalization error. Works.
247
