Faulty NIC on CCM
christianojum
I recently deployed Deployed CCM 6.1.Bus.Edition. The OS is Linux. At a point all the phones lost connection to the CCM. I narrowed the problem to the Network port. The network port is faulty.
How can I revive this bad port. Or how can I assign IP address to the second port for me to use the second port. I need help.
Johann Aicher
Be arare about a Bug in 6.1(2): CSCsv49493
Reg.
Johann
Thanks Johan for your quick response. I have studied the Bug but my callmanager does not have the symptoms contained in the Bug.The sympoms in the Bug is as follows-Symptom:Phone services will go down, and server will only be semi-responsive. Local console access will show the following error constantly scrolling across the screen.
EXT3-fs error (device sd(8,6)) in start_transaction: Journal has aborted)
But the only problem with my CM is that the NIC is not working and hence connot communicate with the network. When i connet to it locally the only error it reported was--'gateway gateway not found'. If the faulty NIC port is revived or the second one is activated, I think it should work. Please I need help on how to do any of these.
Did you get a fix for this issue. We have exactly the same issue.
