Fax and FXS
We have problem with fxs Card.
We can send fax, but not receive Fax.
If i change the fax, with analog phone. I can call outgoing.
But if i call from outside the analog phone it is not working.
Analog phone receive only one ring and no more.
Is there configuration problem, here is the Fxs Configuration :
(FXS card) :
voice-port 0/1/0
compand-type a-law
cptone FR
(Dialpeer) :
dial-peer voice 16 pots
destination-pattern 4658
port 0/1/0
I join the complete configuration
Thanks for your help
1 REPLY
Re: Fax and FXS
The Tac found the solution
Adding this command to global configuration has solved the problem
voice call send-alert
169
