FAX as Email solution in CUCM 7.1
We have CUCM 7.1 and unity express 7.1 in a Bank setup, customer is asking for fax solution now, they are having 250 extension, every one should need Fax number with same DN, the Fax should be send/receive as Email attachement, please let me know solution for 250 user fax solution as email.
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: FAX as Email solution in CUCM 7.1
You can try fooling around with T.37 but I would recommend against it.
http://www.cisco.com/en/US/tech/tk652/tk777/technologies_white_paper09186a00801fe5da.shtml
The correct way to do this is with Sagem-Interstar Xmedius Fax. Everyone who uses this product loves it. You can run it on an AXP blade within an ISR or on a x86 server. Whatever you do, DO NOT buy the Cisco (Captaris RightFax) product. It is horrible by comparison to Xmedius.
I'll tell you now that single-number for fax/voice is problematic. You have to do it through a TCL script on the voice gateway. It's messy, not perfect, and adds delay for anyone trying to call and speak with the individual. Save yourself a lot of hassle and just buy the additional DIDs.
Here are the TCL scripts if you want to look into T.37 or the single number for faxing:
http://www.cisco.com/cgi-bin/tablebuild.pl/tclware
Please remember to rate helpful responses and identify helpful or
VIP Super Bronze
Thanks a lot for your reply, could you please help me to produce a BOQ for this customer, the data sheet is not guide with ordering guide.
Data sheet of FOIP
http://www.cisco.com/en/US/prod/collateral/routers/ps9701/data_sheet_c02_459083.html
Guys
I am using MGCP gateway with CUCM 8.6. Can you please help me to use fax to email on this setup? I know we have configure fax to email on gateway througn mmoip but i want to achive through cucm?
Please advise.
SS
If I have not overlooked anything (and that is possible) you want be able to do it just with Cisco and GW - you do not have t.37 as an option in your configuration. Seek fo 3rd party solution - and you can try us or other foip product with such functionality - some examples:
http://developer.cisco.com/web/partner/search?text=fax+server&technologyIds=&subTechnologyIds=&technologyProductIds=&technologyProductVersionIds=&partnerProductFamilies=&verticalIndustryCategoryId=&availableVerticalIndustryCategories=&_regions=on&_re...
Feel free to ask me any question.
Jiri
BTW We are Cisco Preferred Partner -
http://developer.cisco.com/web/partner/search?accountId=0014000000OZ88uAAD
I agree with the Jonathan, T.37 is an option if you can not use something else. It works but it has its disadvantages.
We are also in business as RightFax and Xmedius. So you should consider also our product - www.2ring.com/netfax - it just works. Find the best solution that suits your clients needs, and save them their $.
If you want to have price points and requirements, just let me know.
Jiri
BTW I am leading development of this product, so you can ask me even more about it.
3058
