Community Member
fax busy tone
Hi all ,
People are tryin to send fax to our comapny complains they are getting busy tones  . Here is my confiuration on the gateway .The ip address in the
configuration are for interaction server (the server process the fax) .
voice gateway is Cisco 2821
PSTN connectivity :, PRI
Please help .
dial-peer voice 899 voip
destination-pattern 2xxx8425
session protocol sipv2
session target ipv4:192.168.2.10:5062
dtmf-relay rtp-nte
codec g711ulaw
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
no vad
Everyone's tags (2)
Re: fax busy tone
Your destination pattern should be 2... Not 2xxx and try your dtmf-relay as h245 alphanumeric. Also can you give us a debug voice dialpeer inout on such a fax call
Voice CCIE #37771
Community Member
Re: fax busy tone
Sorry for the  confusion
Pattern actually i masked , it s  full number
124
